Electronic Ignition
https://www.slantsix.org/forum/viewtopic.php?t=5326
Author:  cycledog [ Tue Mar 25, 2003 5:17 pm ]
Post subject:  Electronic Ignition
Chrysler no longer has the electronic ignition conversion for the slant. Where do I go from here. Finding a distributor is no problem or the ecu, but which balast resistor do I need and where can I find a wiring diagram to wire it properly?
Thanks,
C-dog
Author:  Pierre [ Tue Mar 25, 2003 5:56 pm ]
Post subject:  diagram
On the main page of this site click the articles link, there is a picture of the proper wiring diagrams. The ballast can be bought from your local autoparts store or a junkyard.
Author:  cycledog [ Tue Mar 25, 2003 7:54 pm ]
Pierre,
Thanks, I am such a dork.....I knew that. Hello Mcfly.........
Author:  Pierre [ Tue Mar 25, 2003 8:21 pm ]
Post subject:  while we are on the subject...
Does anyone know what kind of ignition was in a 87 dodge ram /6 truck? Is it the same electronic ignition as in the 73+ cars, the same parts?
Author:  '74 Sport [ Tue Mar 25, 2003 10:48 pm ]
Post subject:  Should I consider a new ignition system?
Both the electronic ignition control and the voltage regulator on my '74 Dart Sport had some kind of sticky goo running down the inner fender. Should I replace them with similar components and hook everything back the same way, or should I consider going with some currently available ignition system? Any recommendations on which one?
