| Slant Six Forum https://www.slantsix.org/forum/ |
| Rebuild manuals https://www.slantsix.org/forum/viewtopic.php?t=5439 |
| Author: | topferment [ Wed Apr 09, 2003 8:15 pm ] |
| Post subject: | Rebuild manuals |
I need a good engine rebuild manual for a slant 6. If anyone could suggest one or more I would greatly appreciate it. Thanks. |
| Author: | Red [ Wed Apr 09, 2003 8:50 pm ] |
| Post subject: | manual for rebuild |
A factory shop manual is great to have. Here are 3 leads for finding one. You can do a search on Google for "automotive shop manuals" to find other venders, but these 3 are a start. Get the one that covers your specific year and model. http://www.autolitshop.com/shop/searchr ... 640CS5YJCR http://www.auto-shop-manuals.com/ http://www.gearheadcafe.com/cddetails.html ------------------- 2 other great books: Step-By-Step Guide to Engine Maintenance/Repair:The Chrysler Family" By Herschel & Ray Whittington TAB BooksISBN#0-8306-5848-3 this book is out of print, but I found one here: http://www.amazon.com/exec/obidos/subst ... 96-7813549 this is a site that sells used books. I had to check back several times before a copy finally showed up...this was probably not a real big printing and it has been out of print for some time. But there ARE copies floating around out there if you are persistent in your search. ------------------ Another great book which is still in print can be seen here: http://www.slantsix.org/articles/sa-fra ... hapter.htm ------------------ The Mopar Engines Manual, available at most dealerships is also a good source of information. I'd check to make sure that it still contains a slant 6 section before I order it, though. My older edition does. I've also seen another, smaller version of this which covers Mopar V-6 and slant 6 only. Hope this helps. ---Red |
| Author: | topferment [ Wed Apr 09, 2003 9:15 pm ] |
| Post subject: | manuals |
Thanks for the info Red, I'll give those a try. |
| Author: | Red [ Wed Apr 09, 2003 9:34 pm ] |
| Post subject: | factory manuals |
Or: http://www.stores.ebay.com/faxonautolit ... index.html ---Red |
