It is currently Wed Jun 17, 2026 7:43 pm
PostPosted: Tue Oct 14, 2014 4:51 pm
Car Model: 87 B150, 1970 Valiant 4-door
Tore down my R8831A to soak in Berrymen overnight and all day today.
Check ball did not fall out during disassembly. I figured it would turn up in the solvent can or come loose when I take it out of soak.
No luck.
Figured it was lost until i tried to blow carb cleaner down the hole.
It was still in there.
Put old pump cup on a pin punch, filled pump cylinder with carb spray and tried to 'pump' it out. No good.
I slid an old fuel line over a blow gun, wrapped a big ball of teflon tape around it to make a seal, shoved it in the pump bore and pulled the trigger.
No good.
I poured a little acetone in the ball hole and the cylinder and let soak a few minutes (I'm sure it was eating the finish off the fuel bowl). I'll try blow gun tomorrow night after the residual acetone has evaporated. I don't hold out much hope.
I entertained heating with a propane torch. Not sure how stupid that is.
Also, what is 'staking?' Locktite? Red Head? Something else?
Any advice is greatly appreciated.
PostPosted: Tue Oct 14, 2014 5:08 pm
Does it need to come out?
PostPosted: Tue Oct 14, 2014 5:18 pm
yes. (it is the root of the problem that precipitated the tear down: no pump shot.)
PostPosted: Tue Oct 14, 2014 5:43 pm
staking is when you use a pin punch to mess up a good fit so the ball wont move.
PostPosted: Tue Oct 14, 2014 5:59 pm
to clarify: I didn't touch the punch to metal. I stuck the tip of the punch in the hole of the cup, and used as a piston to compress carb cleaner into the passage with the ball in order to dislodge it.
PostPosted: Fri Oct 17, 2014 10:57 am
I read on the Mike's Carburetor blog that reasonable heating is ok.
I flipped over fuel bowl and heated approximate location of ball with propane torch from inside the carb throat while tapping with a screwdriver handle.
It fell right out.
