| Slant Six Forum https://www.slantsix.org/forum/ |
| burning coolant https://www.slantsix.org/forum/viewtopic.php?t=56414 |
| Author: | Valleyant [ Sun Oct 19, 2014 4:54 pm ] |
| Post subject: | burning coolant |
Mostly visible on cold start ups. I just switched to conventional coolant from evans just a few days ago. Has been almost 2.5 years since milled head/new felpro head gasket. Should I try a head bolt retorque first??? Burning coolant did not seem to be an issue before the switch to conventional coolant. thanks for the help! |
| Author: | Valleyant [ Mon Oct 20, 2014 4:25 am ] |
It seems like one or more cylinders is missing on cold start up....I guess some coolant is seeping into the cylinder/s.....it smoothes out in roughly a minute.....but I definitely know coolant is being burned.... I will check the plugs in hope of finding where the problem is........what aggravates me is that I just installed a Cloyes double roller timing set and the car runs much stronger now. |
| Author: | nm9stheham [ Mon Oct 20, 2014 10:25 am ] |
You ought to see some evidence in a color change on those cylinder's plugs and some crusty particles or deposits; might not be much but it'll be there. A retorque is worth a shot, but not likley to fix it IMO so long after the gasket was installed, unless a head bolt really backed out a lot. (Again not likely.) |
| Author: | Valleyant [ Mon Oct 20, 2014 1:35 pm ] |
Thanks, I know it is wishful thinking but I will inspect the bolts/tightness on tear down....I guess I know what I will be doing on one of my upcoming weekends! |
| Author: | Valleyant [ Tue Oct 21, 2014 4:20 am ] |
Ok, no leak down or compression test performed but I think I can be pretty confident that I found the problem. One or more of the I/E studs near #6 are leaking and streaking downward on the block. That's my focus now. |
