It is currently Fri Dec 26, 2025 8:15 pm
 Post subject: My Weber DCOE Install
PostPosted: Mon Jun 04, 2018 5:53 pm
Car Model: 1965 2 Dr Sedan, Wagon, Barracuda and Convertible
Hey. I'm finally getting my triple DCOE 40 setup running. I've had this stuff for almost 20 years. I've had to figure out a bunch of details and I'm sure I'll find a bunch more before I've got it right.
1. I did have to get a local muffler shop to cut and reroute the No 6 Header tube so it cleared the WEBERS. You'd think that a Clifford manifold would clear Clifford headers. It clears now but not by much. We'll see how much of a heat problem it is.
a. I also had to grind on the intake to get the "Cold Start Device" to clear. I'll probably remove and block those off eventually.
2. I've goofed around with a bunch of linkage ideas. I think what I have now will work. It's a triple Weber kit from Pierce Manifolds. There wasn't enough clearance for the lower pivot nut to clear the carb body. I had 2 choices. Grind off the interfering mounting point on the Weber or get throttle arms with the ball attached. I decided to go with the arms with the ball attached. (Not part of the original kit)
3. I thought about keeping the solid linkage and somehow rigging up a push rod from the transmission kick-down to the throttle rod. Too much trouble and too far out on the end of a non supported rod for me. Decided to change over to a later A-body hanging pedal and cable that comes up under the carbs and attaches beside the middle Weber. Much neater but pretty close to the headers. We'll see. I might need to make a heat shield.
4. Not sure what to do about the Distributor Vacuum. Probably just cap it and live without it.
5. PCV Valve. That's what I'm thinking about now. I have a Vacuum port on the 6th intake runner. I wonder if would work to plumb the PCV valve through a catch can and into the no.6 runner? Anyone else out there thinking about this? It's a 1965 so I don't think it has to have a PCV valve. Some did, some didn't. The breather is also the type that attached to the air cleaner. Not practical on the Webers.
6. For now I'm using the stock fuel pump. I have a whole setup with a Carter Electric with constant low pressure. Recommend for the Weber DCOE. They don't like much pressure. Maybe 4psi from what I've read. Haven't installed it yet. Hopefully I'll be on the car for the Reunion.
You guys rock. Thanks for all the advice over the years. Hope to see you at a race soon. Fingers crossed on the Webers. If not I'll just stick the Offy and AFB back on.
1965 Valiant 200 /6 2dr Sedan.
1965 Valiant 200 V8 4dr Wagon
1965 Barracuda /6
1965 Valiant Convertible V8
PostPosted: Mon Jun 04, 2018 7:00 pm
PCV should really go to all. Is there a balance tube for the webers?
You could try manifold vacuum for the distributor.
PostPosted: Mon Jun 04, 2018 7:40 pm
Nope No balance tube unless I make one. One barrel One cylinder
Same with Vacuum advance.
1965 Barracuda /6
PostPosted: Mon Jun 04, 2018 7:47 pm
PCV on one cylinder would throw that cylinders AF ratio out of balance.
Vacuum on one cylinder would have it bouncing.
That leaves you with a road-draft tube and no vacuum advance (unless somebody comes up with another idea)
PostPosted: Tue Jun 05, 2018 9:24 am
What do guys with forced induction do? You don't want pressure blowing INTO the head.
I may end up running it into a catch container.
I've thought about making a balance tube across the top. Wouldn't be that hard. Kind of a PITA
1965 Barracuda /6
PostPosted: Tue Jun 05, 2018 10:33 am
PCV valve is one way, so no problem with boost. I am running a stock PCV at 14 psi boost.
Users browsing this forum: No registered users and 19 guests
