Head gasket
https://www.slantsix.org/forum/viewtopic.php?t=62424
Author:  Challenger [ Thu May 31, 2018 2:39 pm ]
Post subject:  Head gasket
Where do you purchase a good head gasket for a race motor. The last one I purchased was from Cox Brothers and was a copper gasket. I know they haven’t been selling for slants and I will need one when I put my motor back together. Also will need freeze plug kit for this motor. Any help will be appreciated.
Author:  Dart270 [ Thu May 31, 2018 3:06 pm ]
Post subject:  Re: Head gasket
What is your static compression ratio? Fel Pro is good up to about 11:1. The Aussie gasket (composition) is good to about 12:1.
Author:  Challenger [ Thu May 31, 2018 3:58 pm ]
Lou it is suppose to be 10 to 1 according to Gary Bruner who built the engine. Does felpro have a web site I can order from. Thanks Norm
Author:  DusterIdiot [ Thu May 31, 2018 4:56 pm ]
Just order an engine rebuild kit, you get extra gaskets you may need later and the head gasket alone costs about 1/3-1/2
the rebuild kit. You can get them at Rock Auto, or order at Auto zone... FS7918PT-4 for the full gasket set at about $70...
Head gasket only... 7918PT-1 and is $23+
I used a felpro gasket on an 11:1 engine and it blew on a freshly milled flat deck and head... a number of killer bees
use the victor reinz gasket on their rides, I have fired off the 12.3:1 engine and no issues with that gasket...previously
switched tot he Reinz gasket on that 11:1 motor and had no problems with it.
Author:  Dart270 [ Thu May 31, 2018 5:54 pm ]
If it is only 10:1, I think any gasket you can find will work fine. Victor should be available at any parts store (order 1-3 days?) or the Felpro.
Author:  Rick Covalt [ Fri Jun 01, 2018 3:15 am ]
How big is the bore?
Author:  slantzilla [ Tue Jun 05, 2018 10:04 am ]
IIRC, Jim still had an assortment of copper gaskets last March at the ICH Swap.
Author:  SpaceFrank [ Tue Jun 05, 2018 7:47 pm ]
I trust any of these guys if they say the Fel-pro head gasket will work fine for your application, but if you're buying an entire engine gasket kit then I'd go ahead and step up to Victor Reinz to get a better manifold gasket. I've never gotten a Fel-pro manifold-to-head gasket to seal correctly. Any of these, as well as the expansion plugs, can be found on RockAuto.
If you're running a stock exhaust manifold, neither of those kits will have a good gasket for the heat riser box. I'd go with the Remflex gasket for that.
