It is currently Fri Jan 02, 2026 2:05 pm
PostPosted: Mon Jan 12, 2004 9:18 am
Am I right in thinking that the truck Slant 6 is the one with the sump the furthest toward the back?
Other than sump location, all oil pans are interchangeable among the Slant 6 family aren't they?
The pickup tube would have to be the right one to match, but what about the dipstick?
Are there any good sources for aftermarket pans for the Slant 6?
Thanks!
PostPosted: Mon Jan 12, 2004 11:10 am
The pans and sticks are different for vehicles independent of the block. Try mother mopar for parts first, they fit and take the guess work out of the equation. :twisted:
D-100 sl6 all mopar when they still sold the good stuff!!
 Post subject: pan ponderings
PostPosted: Mon Jan 12, 2004 11:11 am
the sump IS different for different applications as well as the dipstick. Try your dealer for parts first!
PostPosted: Mon Jan 12, 2004 11:19 am
Car Model: '23 T-bucket
Rob; You're correct as far as you went. Vans (with slant) also use the rear sump pan. If I'm not mistaken, all others were a mid-sump configuration. As Damxwiz said, though, the pan is dependent on the vehicle it's mounted in.
Roger
Users browsing this forum: Google [Bot] and 30 guests
