It is currently Fri Jul 11, 2025 1:13 pm
 Post subject: Misc slant 6 parts
PostPosted: Fri Jul 04, 2025 3:03 pm
Cast iron S6-SB trans adapter with crank spacer $250
AR engineering S6-SB aluminum adapter kit $400
Wilcap S6-GM trans kit $650
73-76 A-body S6 K-frame $100
K1 7 inch rods for forged crank and Wisco 45 over piston and ring set for turbo or nitrous. They were ordered with low 7 1/2:1 compression ratio for 30+ PSI of boost $1,000
Sale pending on the trans adapters and pistons rod.
NOS late 80s exhaust manifolds $200-250.
Used exhaust manifolds $50-$75.
Forged 225 crank $100.
I will be taking the following unsold parts to Carlisle on Friday only.
NOS exhaust manifold with stud kit and heat stove $250
Zollner NOS 20 over piston set, this was the OEM vendor for S/6 pistons. $150.
My distributor spring kits $25 each
NOS head gaskets $75 each
Last edited by bigslant6fan on Thu Jul 10, 2025 12:29 pm, edited 3 times in total.
 Post subject: Re: Misc slant 6 parts
PostPosted: Fri Jul 04, 2025 4:57 pm
That is some great parts Charles! Now if I was doing a turbo.................. :D :D
PostPosted: Sun Jul 06, 2025 6:30 pm
Car Model: 1962 Dodge Lancer
What all does the GM trans kit come with?
PostPosted: Mon Jul 07, 2025 8:29 am
Car Model: Slant Six M37
Any distributor re-curve springs left..?
