It is currently Thu May 21, 2026 11:52 am
 Post subject: I cant do it
PostPosted: Wed Sep 17, 2003 12:41 pm
can you guys help me??? i dont understand the directions to rebuild a carter, am i stupid how is it done i really need help!!!!!!
PostPosted: Wed Sep 17, 2003 1:06 pm
PostPosted: Wed Sep 17, 2003 1:45 pm
take the carb apart and keep track of all the parts and where they go. Clean all the parts in carb cleaner then reassemble clean parts with the new gaskets in carb kit. pay attention to the small spring and brass part attached to the float make sure they are assembled exactly like they were when you took the carb apart. good luck
-Doug
PostPosted: Wed Sep 17, 2003 6:33 pm
the fuel pump and i cant replace it so i am buying a new one!! :D
PostPosted: Wed Sep 17, 2003 6:47 pm
Not sure what you are replacing. please clarify...Dave
