It is currently Mon Dec 29, 2025 10:40 pm
 Post subject: Oil Pan for Truck?
PostPosted: Mon Oct 20, 2003 11:10 am
Car Model: 71 Dodge D100 64 Plymouth Valiant Wagon
Is the oil pan for a truck different than the one for a car? I've got a 71 D100.
And where's a good place to find an oil pan and how much should I pay?
thanks,
Joe
Joe Hoppe
71 D100 225 Super Six 727 AT on 2008 Crown Vic CopCar frame
64 Valiant Wagon 225 904 AT 3:23 8.75"
 Post subject: Oil pan for truck
PostPosted: Mon Oct 20, 2003 1:21 pm
The truck pans should be different as many of them had a deeper sump. A car pan may fit as long as there are no problems with the cross member/steering componets. I have a six quart truck pan and pick tube from a '63 D100 if that helps.
 Post subject: Looking for a new pan
PostPosted: Mon Oct 20, 2003 4:31 pm
Thanks, RG, but I've had enough problems with valve covers lately to not what to go near a used oil pan.
Appreciate the info,
Joe
Joe Hoppe
PostPosted: Mon Oct 20, 2003 4:35 pm
Aren't truck/van pans rear sump vs car pans center sump? Be careful about that if your going junkyard hunting.
Used pans are fine, you just have to make sure the sealing lip is nice and flat. Flatten it out as much as you can with a hammer before you put it back in and then the gasket/sealer will work lots better.
PostPosted: Mon Oct 20, 2003 5:16 pm
I have a car pan on my 71 d100 with no problems whatsoever and the engine that I removed from it had a 6 qt front sump pan ,also no problems.The 61-71 d100's will accept most any pan ,mine clears just fine even with 2 inch lowered springs(remember the 71 had a straight front axle).
Slanted Attitude
Ive got a slanted attitude and a heavy right foot.
