| Slant Six Forum https://www.slantsix.org/forum/ |
| Advice Needed https://www.slantsix.org/forum/viewtopic.php?t=7298 |
| Author: | Big-O Teets [ Mon Oct 20, 2003 8:47 pm ] |
| Post subject: | Advice Needed |
| Author: | Pierre [ Mon Oct 20, 2003 9:32 pm ] |
Is the transmission out of the car that the engine is going in? I find it easier to bolt engine to tranny outside, then install em both at once instead of trying to align block with tranny in the engine compartment. It's not that big a deal, but just makes it easier. |
| Author: | Big-O Teets [ Tue Oct 21, 2003 6:16 pm ] |
The transmission was left in the car. |
| Author: | Eric W [ Tue Oct 21, 2003 7:43 pm ] |
If you can get somebody to help you, you can lower the engine in and your helper can work the floor jack under the transmission to get it to line up. Took no more than 15-20 minutes when I replaced the engine in my Satellite doing this. Of course, you could do it yourself, might just take alittle longer...and you'll be up, down, up, down.... |
