It is currently Thu Jun 25, 2026 1:25 am
PostPosted: Fri Oct 31, 2003 2:12 pm
Cool forum. Here I go.
My engine: 225 slant 6 1bbl (what does 'bbl' stand for?)
What I want: 225 slant 6 2bbl
Why: Better performance from what I've read
Who am I:
I am someone who doesn't know a great deal about engines, but I'm mechanically savvy, eager to learn, and recently purchased a factory service manual for my 78 D100 truck. I want to do things the right way; however, I'm a bit apprehensive about getting too deep and screwing things up.
Question:
To super six my truck, should I:
1. Get a 2bbl carb with an adapter so it fits my 1bbl manifold
or
2. Get a 2bbl carb and replace my stock manifold with a 2bbl manifold?
To me, the right thing to do would be to match the carb ports with the intake ports and not use an adapter, but remember, I don't want to get in over my head. The adapter is the simpler method, right?
Another consideration is the performance of the engine. Wouldn't using an adapter to fit my stock manifold give poorer performance that if I changed to a two port manifold? I always appreciate getting advice from the voices of reason and experience, not to mention learning from others' mistakes.
Thanks,
Chris
 Post subject: here ya go...
PostPosted: Fri Oct 31, 2003 2:19 pm
http://slantsix.org/articles/supersix/article.htm
this is a link to an article that tells you everything you need to know....
theres lots more articles on the main site:http://www.slantsix.org
welcome to the site!
 Post subject: Re: here ya go...
PostPosted: Fri Oct 31, 2003 2:25 pm
that's the first article I read. In fact, it's how I found this forum via a google search. That article is what got me interested in the super six upgrade to begin with.
Thanks for the welcome. Lots of useful info here.
PostPosted: Fri Oct 31, 2003 2:36 pm
If it were me, and it is, because I'm doing the exact same thing. :shock:
Buy the complete super six setup. You will not be getting in over your head, due to the fact that a manifold swap is basic. A monkey with a hammer could accomplish this task. In my opinion, just swaping in a two barrel Carb., is pointless. If the added performance is what your after, then do it right, and install the 2-barrel manifold with the 2-barrel carb that it was designed to run with.
Good luck, and remember-This is just MY .02cents
Hellbent Rods & Custom fabs
PostPosted: Fri Oct 31, 2003 2:44 pm
Thanks for info. What carb are you using? Did you find your setup in a salvage yard or buy it from someone here?
And what's 'bbl' stand for, since barrel just has one 'b' in it.
PostPosted: Fri Oct 31, 2003 4:12 pm
Actually, "bbl" IS just shorthand for barrel. Sometime, when they get worked up, the old timers will call them "two bubble" carbs.
I agree. Go for the full upgrade, manifold and all. A super six manifold is a good performance upgrade because there are a large variety opf adapters which allow you to mount a large variety of carbs on the manifold.
Good Luck!
Reed
P.S. Thanks for the compliments on the article guys! I'm glad it was helpful. I have been kicking around the idea of an update but it will have to wait at least until I am done with law school.
 Post subject: My .02
PostPosted: Fri Oct 31, 2003 4:15 pm
AFAIK- "bbl" stands for barrel, even though there is only one 'b' present. Sometimes you may also see '2v'. The 'v' stands for venturi, same animal different naming convention.
[Edit: Looks like Reed beat me to it ;) ]
http://www.prolinefuel.com has adapters and Weber 2 bbl carbs that can be mated directly to your stock 1bbl manifold. Do a search on "weber" and "adapter plate" both here and over at http://www.slantsix.com and you should come across a wealth of information on this setup. From what I have heard seems to work very well.
That being said, swapping on a true supersix setup (2 bbl manifold and carb) is not that involved of a task, as has been stated. The hardest part is re-installing all those blind nuts and triangular washers on the bottom of the manifolds--and perhaps taking the intake and exhaust manifolds apart without breaking the bolts.
Check out proline's site and the parts for sale sections here and at ss.com and you should find what you are looking for. Good Luck :)
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Fri Oct 31, 2003 4:26 pm
Be Bop a Lula,,,, No, it's barrel. Engines with super six are using normally Carter bbd (2bbl) carbs.
Joug[/b]
Sorry, my english is not very good
 Post subject: I'll be damned!
PostPosted: Fri Oct 31, 2003 7:44 pm
I took my factory service manual out to my truck tonight, popped the hood, removed the air cleaner and actually looked at my carburator up close, comparing it to the Holley and Carter carb pictures in my manual for the 225 engine. To my surprise, I'll be damned if it doesn't already have a super six setup and I didn't even know it! It's a Carter BBD-8149S (written on the bar code label on top). I had to wet my finger and rub it across the grime to read the numbers, but that's what I got! Shazzam!
I suppose a rebuild is in order now to celebrate my serendepitous discovery?
Some background info:
The truck was given to me by my grandfather a couple months ago. It had been sitting in his carport on rotted tires for several years, unstarted all those years I suspect. I had to have it towed to a service station, replace the battery, new tires, replace a few hoses and fluids, and the front brakes. I then drove it 250 miles back home. It's in wonderful condition and I'm just now digging into it.
Users browsing this forum: Amazon [Bot] and 3 guests
