It is currently Tue Dec 30, 2025 9:19 pm
 Post subject: 2 bbl bolt patterns?
PostPosted: Thu Oct 23, 2003 1:22 am
The carter BBD bolt pattern is the same as a Rochester 2 Jet, correct? Whats the CfM ratings on the 318 bbd versus the super six? I decided against the holley 4412 becuase of space limitations, any carb suggestions? Thanks.
-Jesse
PostPosted: Thu Oct 23, 2003 3:59 pm
I am not sure on the CFM ratings, but the racing manuals state that the 318 BBD is worth 5% more HP then the \6 BBD.
PostPosted: Thu Oct 23, 2003 4:59 pm
Cool thanks, is that 5% on a \6? What year would be the best to use(318 BBD)?
-Jesse
PostPosted: Fri Oct 24, 2003 1:31 pm
I got mine off of a 79 volare wagon with a 318
PostPosted: Fri Oct 24, 2003 4:24 pm
I perfer carbs from before '73. Less junk hanging off them.
PostPosted: Fri Oct 24, 2003 5:09 pm
There wasn't any "junk" hanging on this one. Just the choke pull off. I had to plug about 5 vaccum nipples.
PostPosted: Sat Oct 25, 2003 1:46 am
The excese vacum ports wont be needed(I only need 1), so 73 is probably a good cutoff year so I don't get to much smog BS. What about a B motor or a bigger small block BBD(might be abit big tho) my ideal CFM is anywere from 350-450 so I may have to do some searching.
-Jesse
PostPosted: Sat Oct 25, 2003 4:45 am
You don't want a BBD then, they only flow around 280-290 cfm. I'm sure I got really lucky when I found mine. It looked(and still does) just re-manufactured and some one knew what they were doing when they tuned it. I felt an increase in power and got a 2 mpg boost just by bolting this carb on.
The only vacuum ports I am using are the vac advance and hot air intake valve in the winter
 Post subject: 350 CFM=Holley 2300
PostPosted: Sat Oct 25, 2003 10:18 am
If you're looking for that kind of CFM, you'll be paying for a mr.Gasket #1937 adaptor kit and going to the Junkyard and finding a Holley 2300 off a Ford V-8 2 barrel (early-70's are more common in some places).
I have one in my stash off a mid-70's 302 and it has the 'economaster' venturies that have a bit more restriction than the standard ones, this will increase signal and atomization.
PostPosted: Sun Oct 26, 2003 7:40 am
Or you could try to find a Rochester 2G from a Chevy 327. I believe they are in that CFM range. No adapter needed. Any 2v from a 350 or larger engine will need some sort of an adapter. A Rochester will need linkage fabrication.
PostPosted: Mon Oct 27, 2003 12:51 pm
I had a 2300 series 500 cfm that was going to go on it(when I ws going to put a turbo on to), but i want a lil' less now. That is why I was thinking BBD, but maybe I will just put a rochester on it.
-Jesse
Users browsing this forum: Bing [Bot], Google [Bot] and 7 guests
