It is currently Sun Aug 30, 2026 11:45 am
 Post subject: Super Six conversion
PostPosted: Wed Nov 05, 2003 10:08 pm
What do i Have to purchase to make this conversion in my 1966 Valiant 170:? i already have the intake coming in the mail. thanks.
--alex
PostPosted: Thu Nov 06, 2003 8:15 am
http://www.slantsix.org/articles/supersix/article.htm
Bare minimum purchase for your 66 slant car would be:
intake, carb, choke pulloff assembly, kickdown linkage form the two barrel slant (if you have an automatic), new aircleaner (aftermarket or factory Super Six or 318 two barrel), and most importantly a cable style throttle linkage. You almost definitely have a rod style throttle and this will not work with a super six without some extensive modifications. You may also have to buy a new exhaust manifold or modify your old one to make the two barrel choke pulloff work.
Done correctly a Super Six conversion is much more than a manifold swap only. However, if you have a manual transmission car, you can get away with swapping the intake, using an adapter to mount a carb that has an electronic choke, using a cheapo after market open element air filter, and only have to worry about the throttle linkage.
Reed
Users browsing this forum: Google [Bot] and 25 guests
