It is currently Thu Jun 11, 2026 2:44 pm
 Post subject: Ballast resistor located
PostPosted: Wed Nov 05, 2003 2:02 pm
I got a 1985 D-100 pickup and would like to no where the ballast resistor is located. Looked on the fire wall and have found nothing or nothing that looks like one.
PostPosted: Wed Nov 05, 2003 4:02 pm
You probably do not have one---most likely a lean-burn ignition or Spark Control Computer (SCC). Lean burn will have a "computer" on the aircleaner housing. SCC would be behind your battery up under the driver front fender. Both models have a distributor with two magnetic pickups (2 sets of wires coming from the dist) and no Ballast Resistor, IIRC.
-S/6
The "Silver Bullet"
87 Ram D150
PostPosted: Wed Nov 05, 2003 10:00 pm
I'm new to Mopar products, know about GM products but what is the difference between lean burn and SCC. My truck has nothing on the air breather. It does have a dual pickup distributor and its new. Keep fighting that miss or rough idle. Bought rebuilt carb from Advance Auto and after reading some topics on this forum my problem could that carb.
PostPosted: Wed Nov 05, 2003 11:29 pm
Have you checked your valve lash recently? That's a common cause for a rough idle/miss. They should be close to .010 intake, .020 exhaust. -zorg
 Post subject: Not on his slant....
PostPosted: Wed Nov 05, 2003 11:49 pm
Zorg...starting in 1981 model year slants the lifters are hydraulic, there is no lash to be set on these motors...
Though he could have a peice of carbon lodged on top of a lifter, or a bad seal that lets some oil into the chamber via the valve stem, or just burning oil and fouling the plugs,...
If the plugs are fouled, and the carb is set right, and you aren't ready for rebuild, you might need a hotter plug to 'burn off' the soot...
