| Slant Six Forum https://www.slantsix.org/forum/ |
| G-Tech numbers on a stock 170 https://www.slantsix.org/forum/viewtopic.php?t=7853 |
| Author: | mpgFanatic [ Tue Dec 16, 2003 6:44 pm ] |
| Post subject: | G-Tech numbers on a stock 170 |
I finally attached my G-Tech meter to the windshield and got some preliminary numbers. The good news is that this car can perform a 1/4 mile drag strip test on a public roadway without breaking any speed limits. The other news is that there's plenty of room for improvement. All this, on a low mileage but tired motor with 85 psi cranking pressure, and a 3-on-the-tree that is (remarkably) still quite solid. Seems a bit clunky compared to today's 5-speeds, of course... but there's hardly enough horsepower to matter. (In a 20-second car, what difference is a 1-second shift? Thought you might be interested. Details: 170/1Bbl, non-synchro 3-spd, 3.23rear, P185/80R13 tires, shift points at ~30mph and 50mph (translates to about 4100 rpm, dropping to 2200 rpm.) At 3000 lbs with me in it, that's in the range of 75 HP at the wheels. Assuming 25% drivetrain loss, that's about 95 HP at the crank. Considering the factory rated this puppy at 101 HP, and considering the low compression figures, that's remarkably good! - Erik |
| Author: | 70valiant [ Tue Dec 16, 2003 6:54 pm ] |
I wish I had a G-Tech it would have been fun to see what each little upgrade would have done. Like base then w/ the super six, then electronic ignition, then electric fan and K&N, then the turbo muffler then the 318 BBD now finally head work and headers w/ 2 1/2" exhaust. |
| Author: | DanInNy [ Wed Dec 17, 2003 7:40 am ] |
| Post subject: | eeks |
Trying to picture 30mph in 1st gear... I think my engine ('67 170) would sound like it's about to explode ! |
| Author: | 70valiant [ Wed Dec 17, 2003 1:58 pm ] |
Mine is a 904 w/ a 2.76 rear, when I shift at 4500 I'm going around 42mph the 2-3 shift at 4500rpm is 77mph |
| Author: | mpgFanatic [ Wed Dec 17, 2003 6:05 pm ] |
| Post subject: | Re: eeks- explode? |
Quote: Trying to picture 30mph in 1st gear... I think my engine ('67 170) would sound like it's about to explode !
Yep, that's about what it sounds like to me, too. But I'm sure 4100 rpm is not out of reach for a Slant, especially the shorter-stroked 170. The only reason I chose that speed is because the engine was clearly starting to run out of steam, and felt a bit more aggressive at 2200 rpm in the next gear. (Well, as agressive as a stock 170 gets. Yea, I know, I could have been scientific about it, but I chose the shift point purely based on seat-of-the-pants feel. - Erik |
| Author: | Guest [ Thu Dec 18, 2003 12:17 pm ] |
2.76gears and i shift outta first at 55mph |
| Author: | steponmebbbboom [ Thu Dec 18, 2003 5:36 pm ] |
| Post subject: | Re: G-Tech numbers on a stock 170 |
Quote: it's tough to get consistent results when I have to finesse my foot around a bog in the accelerator pump. (The O2 sensor readout proves handy, to help me get past that.) The 1/4 mile arrives in the low 20s, at about 69 mph.
- Erik An o2 sensor on a 170? I'm obviously misinterpreting this; how does the o2 sensor readout help you on a car without one? |
| Author: | DusterIdiot [ Thu Dec 18, 2003 10:07 pm ] |
| Post subject: | Must be behind the times... |
Quote: An o2 sensor on a 170? I'm obviously misinterpreting this; how does the o2 sensor readout help you on a car without one?
One of the new 'cheats' is to install a bung and one wire O2 sensor in your header pipe right after the exhaust manifold and wire it to a meter or a multimeter to give you an idea during a drive or drag session of what kind of carb tuning you need to do, with the 'input' you make the determination as to changing the jetting, shot size/duration, etc.... instead of a computer. -D.Idiot |
| Author: | steponmebbbboom [ Fri Dec 19, 2003 5:58 am ] |
Cool! I use a thermocouple and pyrometer out of a truck on my VW westy to monitor exhaust temperature and Ive always used that to adjust my mixture, but that's with a stock carb. |
