It is currently Mon Nov 09, 2026 7:24 am
 Post subject: Electronic ignition
PostPosted: Mon Jan 05, 2004 5:46 pm
Hey guys,
I am installing the electronic ign. I got off e-bay. I need you to tell me where each color wire goes. There are 4 pins on the box, and 5 wires, is this normal?? The balast resistor is there and in good shape.
I've got the wires hooked up to the dist. And the wires that hook to the balast resistor are connected. The only wires left are a brown wire, a blue wire, and a black/with yellow stripe. Where do these go??
I also have an electronic voltage regulator with two wires. Can you please tell me where these go also??
Last question-Where can I get parts for the distributor, like the plastic gear, and vacuum advance
Thanks a bunch-Josh
Hellbent Rods & Custom fabs
 Post subject: ECU Alternator wiring
PostPosted: Mon Jan 05, 2004 9:03 pm
Josh:
ECU wiring:
4 pins on the box 5 wires...yes it is ok like that...(newer system)
Alternator connection:
You should have three wires attached to your alternator. The large gauge wire under the screw terminal goes to the battery. The other two should have spade connectors to the field windings in the alternator.
One of these two should be connected to switched 12 volts (12 volts ONLY when the key is on). On the diagram below this wire is blue with white tracer. The green wire goes to the voltage regulator.
Hope this helps.
Please notice....BOTH field wires run to the voltage regulator, the switched wire (blue) is just T'd off instead of going straight to the regulator(it makes several other T's as well). That diagram is nearly identical to my '87 for the charging system, minus the ballast resistor.
Rafa
Hecho en México
Users browsing this forum: Ahrefs [Bot], Amazon [Bot], Bing [Bot] and 5 guests
