| Slant Six Forum https://www.slantsix.org/forum/ |
| striped the dis gear https://www.slantsix.org/forum/viewtopic.php?t=8027 |
| Author: | andrew [ Wed Jan 07, 2004 1:30 pm ] |
| Post subject: | striped the dis gear |
Hey guys I forget who I can get the brass gear from, can someone give me a hint. Thanks. Andrew Wagner Wagnermotorsports.net |
| Author: | Ron Parker [ Wed Jan 07, 2004 4:00 pm ] |
I think Doc has that info. I know you know what your doing but check the cam gear and oil pump gear certain camshafts has been a problem with this. Thanks Ron parker Drake n. Male duck scared of Possum and allergic to Bagel |
| Author: | Charrlie_S [ Wed Jan 07, 2004 5:43 pm ] |
Don't know about a brass gear, but NAPA has a steel dist. gear available. Part number DG-404 |
| Author: | Doc [ Thu Jan 08, 2004 9:48 am ] |
The bronze gears I made were for the oil pump drive. Plastic (nylon) or cast iron distributor gears are available. DD |
