It is currently Mon Nov 09, 2026 12:29 am
 Post subject: striped the dis gear
PostPosted: Wed Jan 07, 2004 1:30 pm
Hey guys I forget who I can get the brass gear from, can someone give me a hint. Thanks.
Andrew Wagner
Wagnermotorsports.net
I will not live without boost again. I just like the sound of the blowoff valve.
PostPosted: Wed Jan 07, 2004 4:00 pm
SSRN National Champion
I think Doc has that info. I know you know what your doing but check the cam gear and oil pump gear certain camshafts has been a problem with this. Thanks Ron parker :D :D
Drake n. Male duck scared of Possum and allergic to Bagel
PostPosted: Wed Jan 07, 2004 5:43 pm
Don't know about a brass gear, but NAPA has a steel dist. gear available. Part number DG-404
PostPosted: Thu Jan 08, 2004 9:48 am
The bronze gears I made were for the oil pump drive.
Plastic (nylon) or cast iron distributor gears are available.
Users browsing this forum: DuckDuckGo [Bot] and 4 guests
