| Slant Six Forum https://www.slantsix.org/forum/ |
| Old alternator with elec. ign.?? https://www.slantsix.org/forum/viewtopic.php?t=8036 |
| Author: | itsa66dart [ Thu Jan 08, 2004 12:52 pm ] |
| Post subject: | Old alternator with elec. ign.?? |
Hey guys, Can I use my single field alternator with my electronic ignition?? Thanks |
| Author: | Charrlie_S [ Thu Jan 08, 2004 4:24 pm ] |
Yes, but I would use an electronic regulator. It looks similar to the original 66 regulator, but not as tall. Most parts stores sell them, if you ask for a regulator for a 66 mopar. Wires hook up the same as stock. If the cover is crimped on, that is the mechanical one, you don't want. |
| Author: | Paul [ Fri Jan 09, 2004 10:54 pm ] |
Charrlie wrote: >>Yes, but I would use an electronic regulator. It looks similar to the original 66 regulator, but not as tall. Most parts stores sell them, if you ask for a regulator for a 66 mopar. Wires hook up the same as stock. If the cover is crimped on, that is the mechanical one, you don't want.<< I would point out that the mechanical regulators I've seen are either held on with 2 rivits or 2 screws. But then again, mine is a '65. Paul |
