What is a good performance CAM choice for a stock 6
https://www.slantsix.org/forum/viewtopic.php?t=8333
Author:  tigersclaw [ Fri Feb 06, 2004 10:22 pm ]
Post subject:  What is a good performance CAM choice for a stock 6
Hi
Can anyone recomend a good cam to up grade to. To get some more pep out of a stock 6 (225).
This is for a auto street car with, everything stock.
I need to replace the timing chane and though while I have it appart I could do a can swap.
Looking for somthing tried and tested and affordable.
And if so, where can I get one from or any for sale outhere.
Many thanks
:wink:
Author:  Doc [ Mon Feb 09, 2004 10:12 am ]
The Mopar 244 degree .435 lift is a good choice.
You may want to search the message board for more info., someone else was recently asking the same question.
Author:  Eric F [ Mon Feb 09, 2004 10:16 am ]
Post subject:  cam selection
either of the comp cams are great the larger would require a 2bbl intake though
Author:  Chuck [ Mon Feb 09, 2004 12:44 pm ]
I have a great Crane cam that gaves good performance and good low end. When the cam gave out, I couldn't get another one because it was no longer available. So Doug had the cam "profiled" for me, then we sent in a used core (with lots of meat on it) and had it cut. I still have this cam in my 255 with a 2bbl carb. Perhaps Doug can still have this done. I really like this cam!
The spec sheet says:
1960-up Slant Six
170-198-225
Good idle, daily performance usage, good low & mid-range HP.
Click here for the spec sheet.
Author:  65DartGT [ Wed Feb 11, 2004 5:57 pm ]
All I can Say is...Clifford performance
