| Slant Six Forum https://www.slantsix.org/forum/ |
| electronic ignition https://www.slantsix.org/forum/viewtopic.php?t=8355 |
| Author: | oibrownskin [ Sun Feb 08, 2004 9:57 pm ] |
| Post subject: | electronic ignition |
Going to electronic ignition on my '66 slant. Still have mechanical voltage regulator, getting a replacement electronic unit. will this be sufficient for my application? (street driving) Caesar |
| Author: | Doctor Dodge [ Mon Feb 09, 2004 4:56 am ] |
I have this exact same set-up in my 66 Dart wagon, I have had 1 ECU failure in the past 12 years, that was with a used ECU. I replaced it with another used ECU. Go ahead and do the conversion and remember, always carry a spare ECU. DD |
| Author: | Michael_Cuda [ Mon Feb 09, 2004 11:39 am ] |
Are all ECU's same for all Mopar engines?.. .excluding Lean burn... |
| Author: | steponmebbbboom [ Mon Feb 09, 2004 5:03 pm ] |
Where is the ECU located on an 87 pickup? |
| Author: | northeast scamp [ Tue Feb 10, 2004 8:05 am ] |
Do a search on ebay for "slant six" and you'll find someone who sells NOS electronic distributors for $50- They usually come up every week or so. |
| Author: | northeast scamp [ Tue Feb 10, 2004 8:07 am ] |
sorry, my previous post was meant for a different thread! |
| Author: | redworm67 [ Tue Feb 10, 2004 10:16 am ] |
according to haynes manual.it should be under the firewall feedthrough,drivers side. |
| Author: | Super6 [ Wed Feb 11, 2004 9:59 am ] |
Steponme... an '87 truck with a slant does not have an ECU unless someone has already converted it to 'standard' electronic ignition. The '87 should have a 'computer' on the drivers front fender behind the battery. -S/6 |
| Author: | steponmebbbboom [ Thu Feb 12, 2004 7:40 pm ] |
Thank you! So will the distributor on that truck be compatible with the standard electronic ignition box? What I want to do is use the parts off that truck on my Dart. Obviously I'm not interested in resurrecting the big ECU I saw right where you said it would be. |
