It is currently Fri Jan 02, 2026 6:59 am
PostPosted: Wed Feb 11, 2004 5:03 pm
Car Model: 62 Lancer GT
The head I got has the air port on the back. I know you can plug it. Are there any problems with these heads? Im stripping it and getting it ready for porting,shaving and valve job.
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Thu Feb 12, 2004 7:44 am
I was just reading some old posts about this and they said this head is much heavier is this true? And how much?
1966 Dart GT
62 Lancer GT
B Body 8 3/4
 Post subject: heavy
PostPosted: Thu Feb 12, 2004 6:33 pm
Car Model: '63 Dart GT Convertible
I could see where the new style head would be heavier than the old head with the spark plug tubes. There is more metal in them. But how much more could it be? Probably not enough to worry about, unless you're racing.
PostPosted: Thu Feb 12, 2004 10:16 pm
The later "peanut plug" head is about 10 lbs. heaver, that extra weight is not a big issue.
I have no "real" data but I would think that these heads are a little stronger and more ridged due to the extra metal and walls formed by the air injection passageway running under the ports.
PostPosted: Fri Feb 13, 2004 12:36 am
if it don't leak,she's a keeper !!!
PostPosted: Fri Feb 13, 2004 5:32 am
Thanks for the info. I am building this head to put on my 88,000 mile 66 shortblock. Is there anything else besides a compression test to check for on the engine. I am a little worried about a new tight higher compression head on the older shortblock. The engine does run good now.
1966 Dart GT
62 Lancer GT
B Body 8 3/4
Users browsing this forum: Ahrefs [Bot], Bing [Bot], Google [Bot] and 9 guests
