It is currently Sat Jan 03, 2026 12:37 pm
 Post subject: Block ID Date
PostPosted: Sun Feb 08, 2004 6:48 pm
Car Model: 62 Lancer GT
What part of the block #s is the date?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Feb 09, 2004 4:31 am
Most SL6 blocks use a letter code in front of the ID number to indicate the date the engine was built.
In this example, the "T" indicates a 1962 engine.
PostPosted: Fri Feb 13, 2004 3:02 pm
In your case, the "T" stands for Truck. the "A" is the year - 1965.
The "22" is the size - 225-cid, and the "9 14" is the month and day it was assembled - September 14 (1964).
The year "T", by the way, is 1963. 1962 was "S".
Bill
Vancouver, BC
PostPosted: Fri Feb 13, 2004 3:38 pm
Bill, the motor in the photo appears to be an aluminum block. Are you sure of your codes? I know the BB Mopar had a T code for trucks, was this used on slant6's also?
Doc, did any trucks get the aluminum block? Or anything other than the A body?
Cecil
PostPosted: Fri Feb 13, 2004 4:54 pm
Cecil
Yes, the "T" code was used on all Chrysler engines. That is one about Chrysler engines, the codes were the same across the board.
However, I missed the aluminum bit. In that case, the "A" stands for aluminum and the "T" stands for 1963. Which would make it a rare engine as they were not produced long into the 1963 model year.
Bill
Vancouver, BC
PostPosted: Fri Feb 13, 2004 7:28 pm
Thanks for the correction on the "T" code being 1963, I was working off of memory....(as they say, the memory is the second thing to go, I don't remember what the first thing is. :wink: )
As you noted, that "T" code on an Alm. SL6 makes it one of the last ones built, not many made it into 1963 vehicles.
Users browsing this forum: Bing [Bot] and 27 guests
