Need engines for crank scraper patterns
https://www.slantsix.org/forum/viewtopic.php?t=8456
Author:  Kevin Johnson [ Wed Feb 18, 2004 10:57 am ]
Post subject:  Need engines for crank scraper patterns
Hi,
I am posting as a guest on your forum (thank you, Chuck!).
My wife, Samantha, and I make crank scrapers for many different engines and we have had a number of people ask us to make patterns for the slant six.
We need to borrow the 170, 198, and 225 short block and pan from enthusiasts in the Tampa Bay area. In exchange you would receive a free crank scraper of your choice. At present we have patterns for about 150 engines. The engine is not harmed as we only need to make a plastic template. We can pick up and return your engines promptly.
For those of you unfamiliar with crank scrapers, they have been in use for at least 40 years (Pontiac GTO 389 had one) and DaimlerChrysler, BMW, and Nissan (among others) use them in some of their current engines. They are different from windage trays though some windage trays have scrapers incorporated into them. This scraper could be used with (and would work well with) the old Mopar and "Mikes" windage tray.
A crank scraper actively strips out entrained oil from the windage cloud which otherwise creates a parasitic drag/load on the engine. This frees up power that your engine is already making. A scraper does not actually touch any of the rotating assembly and still allows plenty of oil to reach the cylinder walls and internally positioned cams, etc.
Thanks in advance for any help you can provide!
Kind regards,
Kevin Johnson
Ishihara-Johnson Crank Scrapers
Land O' Lakes, FL
727 808 8602
Author:  Rick Covalt [ Wed Feb 18, 2004 12:26 pm ]
Post subject:  scrapers
Kevin,
Be sure to post back with a picture a price when you get them completed.
Rick
Author:  steponmebbbboom [ Wed Feb 18, 2004 4:33 pm ]
So what are the differences between a windage tray and a crank scraper? Does a windage tray not scrape oil from the crank already, or does it just create a barrier preventing the oil in the sump from getting entangled in the crank?
Author:  Slanted73 [ Wed Feb 18, 2004 6:07 pm ]
Post subject:  alnong the thought line of steponmebbbboom...
If I had one of these, would I even need a windage tray? Cuz finding one of those isn't easy as it is, and sooner or later I gotta have something in the oil pan. :P
Author:  Brett K [ Wed Feb 18, 2004 7:05 pm ]
Yes the windage tray keeps the oil in the sump from getting whipped up around the crank.... but it doesn't get any oil off of th crank that's already there. The scraper, on the other hand, will clear off the excess oil on the crank, but won't stop the crank from whipping up the oil in the sump.
In a perfect world you'd run both.
If you get these up and running, I'm more than interested in one. for a long rod 225. (stock 225 should work)
Author:  Slant Cecil [ Wed Feb 18, 2004 7:38 pm ]
Kevin, I can get together a 198 and 225 shortblock, pan and PU for you. I may be able to drop them by in a week or two. I'll give you a call in a few days.
Cecil
Author:  Charrlie_S [ Thu Feb 19, 2004 5:18 am ]
I can supply a 170 engine
Author:  Kevin Johnson [ Mon Feb 23, 2004 7:36 pm ]
Post subject:  Thanks!
Thank you everyone!
Samantha and I picked up a 225 this evening and we should have a pattern for it shortly; 170 and 198 to follow.
Kevin
Author:  DusterIdiot [ Mon Feb 23, 2004 9:41 pm ]
Post subject:  So...what if...
Which scraper pattern would I use if I had a 225 with the 198 rods in it????? :wink:
-D. Idiot
Author:  Kevin Johnson [ Mon Feb 23, 2004 10:48 pm ]
Post subject:  Re: So...what if...
-D. Idiot
225
Author:  Kevin Johnson [ Wed Mar 17, 2004 6:06 pm ]
Post subject:  Crank scraper patterns are ready
Hi All,
I will putting up eBay and website ads for the slant six scrapers shortly. You can see pics of them there. Special thanks to Robert and Charlie for lending me engines!
I will still be needing a 198 and Charlie mentioned that the post 1976 225 had a cast crank -- I wanted to check the pattern on one of those.
Charlie lent me a stock windage tray and alternate pan/pickup and there is no problem with using either.
Kind regards,
Kevin Johnson
http://www.crank-scrapers.com
