It is currently Sun May 17, 2026 12:07 pm
 Post subject: Odd Size Crank Bolt?
PostPosted: Sat Mar 20, 2004 9:14 am
I trying to install my damper and have been told that it should be a 3/4" bolt fine thread. But that bolt is too small . . . any idea what size it is?
PostPosted: Sat Mar 20, 2004 11:07 am
You can press the crank pulley onto the crank and leave it that way to get you through, and simply install the crank bolt later. My engine had the threaded hole, but never had the bolt in it, and it survived for 34 years :wink:
I agree having the bolt head there to help you bar the engine over is a nice convenience.
 Post subject: Re: Odd Size Crank Bolt?
PostPosted: Sat Mar 20, 2004 11:19 am
You aren't by any chance using a bolt that takes a 3/4" wrench are you? If you crank's threads are larger than 3/4" fine, someone has stripped it out once and redrilled and tapped it.
PostPosted: Sat Mar 20, 2004 5:06 pm
That's right, the 3/4" measurement denotes the diameter of the bolt's SHANK, not the wrench size.
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 6 guests
