It is currently Fri Jan 02, 2026 6:16 am
PostPosted: Thu Mar 25, 2004 10:55 pm
i have a 85 ram with a much older engine i found this out when i needed to return my tappet cover gasket with my tappet cover what i do know is the gasket they give me was for a 79 and i'm preety sure it's a 225 after that i'm simply guessingi have found the serial number and i think i also have the casting number off the head if they help the serial number reads 0 225 R1 24 2E and the numbers i found on my head are 410362 and 3129 hopefully someone can help me identify this engine and it's oroginal home or give me a site that can do this for me
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Fri Mar 26, 2004 4:37 am
0 225 R1 24 2E
0 - ?? - Would check this. The rest of the number is for a pre-1968 engine, so it should be a letter (P, R, S, T, V, A, B, C)
225 - 225-cid
R - Regular fuel
1 24 - Assembly date - January, 24
2 - Assemble on 2nd shift
E - Cast crank
Bill
Vancouver, BC
PostPosted: Fri Mar 26, 2004 5:05 am
Bill, something wrong here. You stated that was a pre 68, but also a cast crank. The cast crank did not come out untill 1976. Could it be a later hydraulic lifter motor. Something like 81 or 82?
PostPosted: Fri Mar 26, 2004 3:55 pm
they are solid lifters in it not hydraulic but i do have a cast crank if it helps any
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Sun Mar 28, 2004 7:46 pm
mopar freak.....you arent from california are you? i see the canadian flag but I have to ask.
PostPosted: Sun Mar 28, 2004 8:42 pm
My engine has a pad on the drivers side near the back that shows the serial number of my car on it. What does that pad say on your engine?
PostPosted: Sun Mar 28, 2004 9:17 pm
nope i'm canadian never even beed to califoria
the numbers i have posted are the ones on that pad
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Sun Mar 28, 2004 9:34 pm
if it helps at all the engine was a baby blue after i scraped off the greese and sludge that had built up on it
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Sun Mar 28, 2004 10:04 pm
I don't remember on the slants, but on all the V8's I have had newer than 69, the pad that says part of the VIN is along the very bottom of the block, on a machined pad ajacent to the oil pan rail. On smallblocks, the
equivalent numbers to what you have posted are on the front of the block, drivers side just below the head mount surface. The numbers that you have posted appear to have come off the block like right behind the alternator near the #1 cylinder (top of block) Look below the oil pump about the middle, way bottom, on the passenger side. Might have to scrape and spray with brake clean or Gumout, etc to find.
PostPosted: Mon Mar 29, 2004 12:04 am
it's clean no gunk or anything like that on it
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
PostPosted: Mon Mar 29, 2004 6:27 pm
Im pretty sure the pad that had my VIN on it was on the drivers side of the engine, near the back. But definitely check the passenger side over the oil pump too, as don suggested. Those numbers you gave us came from the front of the engine.
PostPosted: Mon Mar 29, 2004 8:28 pm
ok i've looked at the block closer and writen down every number and letter i've found heres what i got
7C this was at the rear and would not be visable with a traany
3C this was at the front and would be coverd by the timing chain cover
2 was found by the oil pump
330-2 found on the left of the block
3399 this is found on both sides of my block in a little pad
AAWJ found on the left of the block
0 225 R1 24 2E found this up by the head on the left front
0F193158 found this at the rear up near the top right side
i don't think there are any more numbers on this block at least none that i can see without attacking the intire thing with my wire wheel thats on the grinder hope someone can tell me what these tell them i do still have a head i can go over but hope i have no need
MOPAR OR NO CAR
1985 Ram
1975 Coronet
1998 Dakota
Users browsing this forum: Google [Bot] and 13 guests
