It is currently Sat Jan 03, 2026 4:34 am
 Post subject: 318 Carter BBD
PostPosted: Mon Apr 19, 2004 10:10 pm
would a carter bbd for a 318 76-77 dodge truck or a 77 dodge car work well on a super six setup on my 7 dart swinger? i just dont know about using the newer carb on my older car, would this work ok? ive also read something about the choke on the 318 carb not working with the super six. any help would be appreciated.
PostPosted: Tue Apr 20, 2004 12:23 pm
Yes, a later 318 BBD will work but there will be some unused vacuum fittings that will need to be plugged.
The choke flap "eyelet" is at a different angle on the V8 carbs but that can be swapped, it just bolts on.
PostPosted: Tue Apr 20, 2004 6:05 pm
im not sure what a choke flap eyelet is. im going to have a super six bbd. will what i need to bolt on to the 318 carb be included with the super six carb more than likely?
PostPosted: Wed Apr 21, 2004 6:41 pm
This article show the eyelet and discribes a "fix".
http://www.slantsix.org/articles/supersix/article.htm
 Post subject: Counter Weight Question
PostPosted: Wed Apr 21, 2004 7:42 pm
does a 73 exhaust manifold have a rectangular counter weight or a round counter weight?
Users browsing this forum: Ahrefs [Bot] and 13 guests
