| Slant Six Forum https://www.slantsix.org/forum/ |
| Holley or Carter https://www.slantsix.org/forum/viewtopic.php?t=9208 |
Page 1 of 2 |
| Author: | moparfreak [ Sun May 02, 2004 11:24 am ] |
| Post subject: | Holley or Carter |
i recently found a Holley 2 bbl carb and was wondering which would be better for my slant already got a 2 bbl Carter and will probably rebuild both just for the fun of it maybe this question has already been ansered but i'm asking again thanks for any input |
| Author: | moparfreak [ Wed May 05, 2004 1:13 pm ] |
no body has the pros and cons of both types or horror stories praise nothing |
| Author: | DusterIdiot [ Wed May 05, 2004 1:41 pm ] |
| Post subject: | either or... |
I've only run the Carter, and had a few problems, just commonly the throttle shafts need to be rebushed and on one rebuilder I couldn't get the body to seal to the top, after pulling it apart and using a steel rule, I found the top of the body and bowl to be uneven/warped, after replacing the body from another donor it went together and worked fine. I haven't worked with the Holley 2280 yet, some guys here have installed one, most of the 2280's I find in yards are the late 80's feedback model for 318 Vans or Trucks... so those definately won't be on my purchase list. If you want to be the 'informer', rebuild both and drive one for a few months looking at gas mileage/tuning/power and then try the other...and let us know what your favorite was... -D.Idiot |
| Author: | Reed [ Wed May 05, 2004 3:51 pm ] |
I have run both carbs, and there is a definite tradeoff. The Carter gives you beter performance, but the Holley will give you 1-3 miles per gallon more. The holleys seem to have fewer problems with the throttle bushing, but the BBD is a great carb if it is tuned properly. Reed |
| Author: | moparfreak [ Wed May 05, 2004 5:50 pm ] |
i was wondering about that i've got 4 incomplete carters here and all seem to be warped but might look better when i get gaskets for the 2 i picked to put together i think my dad needs one to the holley is his but he said he don't like them asked why and all he said was he knew the carters better so he stuck with them if the carter gives me more power it will probably be the one i'm likely to use need as much power as i can get and i can live with a few miles less per gallon i do have 3 slants out back to so i might set one up with the holley have thought of finding a arrow or something like it and putting one in it but thats for later need to get my truck going before i start another project and speaking of projects i do still have a 75 cornet that i will be restoring after my truck is done |
| Author: | Reed [ Wed May 05, 2004 8:05 pm ] |
Punctuation-its a good thing. |
| Author: | johnnysix [ Thu May 06, 2004 12:17 am ] |
I've sufferred fom the warpage issue on the carter in the past....But my supersix volare I just got really runs STRONG with one.Auto choke gave me some problems but replaced with a manual choke ,and now couldn't even imagine going w anything else!!!!!!!!!!!!!!!!!!!!! Also the new NGK Vpower spark plugs REALLY woke the thing up!! |
| Author: | steponmebbbboom [ Thu May 06, 2004 6:55 pm ] |
Quote: Punctuation-its a good thing.
Lights out at eleven, Martha. |
| Author: | moparfreak [ Sun May 09, 2004 9:29 am ] |
sorry we don't believe in that stuff around here |
| Author: | johnnysix [ Fri May 14, 2004 2:33 am ] |
do you mean that i shouldn't run NGK's??????????????????????????????Should run champions,,right??????????? |
| Author: | DusterIdiot [ Fri May 14, 2004 3:44 am ] |
| Post subject: | Check your plug deposits... |
Quote: do you mean that i shouldn't run NGK's??????????????????????????????Should run champions,,right???????????
NGK's run colder than some of the stock plugs, so if you pull your plug and find you're not getting enough heat, you may have to find another brand, currently both of my car run AC-Delco plugs since I have to run a heat range hotter than required and they were the only brand in town I could find for the RTS-45 plug.... -D.Idiot |
| Author: | johnnysix [ Sat May 15, 2004 11:48 pm ] |
I only know that the AC's that were in it were all white colored and shot.The NGK V powers REALLY picked up the accelleration.How long that lasts,only time will tell... |
| Author: | kesteb [ Sun May 16, 2004 8:48 am ] |
In your case, ANY new plug would have picked up the acceleration. Even the .99 autolites. Remember, the ignition system only produces enough voltage to jump the gap in the plug. On a stock engine, anything other then stock replacement parts is kind of a waste of money. |
| Author: | johnnysix [ Tue May 18, 2004 12:30 am ] |
when u r talking about the difference between $7 and $11 dollars,I disagree...would u rather have a Stant Superstat,or an Isreali thermostat??? $8 or $2.99 ???? Original equipment is a long lost term,dude..I don't care what anyone sez,Iwill not run G.M or Ford parts.Everybody say,YEAH"!!!! |
| Author: | kesteb [ Tue May 18, 2004 4:48 pm ] |
Spark plugs are spark plugs, they all do the same thing. If you feel better paying twice as much as I do, so be it. I perfer the money in my pocket, not others. |
| Page 1 of 2 | All times are UTC-08:00 |
