Carter BBD adjustment
https://www.slantsix.org/forum/viewtopic.php?t=9237
Author:  70survivor [ Tue May 04, 2004 10:00 pm ]
Post subject:  Carter BBD adjustment
what should the vacuum reading be at idle for the BBD? Is there preferred jet size to achieve a balance of performance and MPG? If there is, how would I go about changing jets and where would I get them?
Author:  Doctor Dodge [ Wed May 05, 2004 12:40 am ]
Do you have the original SL6 BBD carb. or is it a BBD off a 318 V8?
Read thru this info. there are some adjustments you should check:
http://www.slantsix.org/articles/supers ... e-list.htm
