| Slant Six Forum https://www.slantsix.org/forum/ |
| Please help- engine coolant plugged? https://www.slantsix.org/forum/viewtopic.php?t=9916 |
| Author: | phogroian [ Sat Jul 24, 2004 11:21 pm ] |
| Post subject: | Please help- engine coolant plugged? |
My 1965 Valiant (225 Slant 6) heats up fast and dumps plenty of hot water (under pressure) into the radiator, but the engine overheats- it is as if the coolant isn't getting through the engine. I understand that there is an engine block cleanout plug and I think it is the little one near the firewall, but I can't work it loose- I rounded off the bolt. What is going on with the engine? I tried removing the thermostat and adding system flush to improve circulation and clear out sludge, but no success. |
| Author: | Michael_Cuda [ Sun Jul 25, 2004 12:07 am ] |
The Block coolant plug on the left side of your engine(facing it w/ hood open), between the firewall and the oil filter.. if you get it out you will likey have to use something to clean it out... mine was very plugged up from sitting for 20 years... You may have to pull your freeze/soft plugs and clean out the water jacket. GL |
| Author: | phogroian [ Sun Jul 25, 2004 10:08 am ] |
Thanks- What do the freeze plugs look like? Where are they? |
| Author: | Michael_Cuda [ Sun Jul 25, 2004 11:16 am ] |
They are round brass plugs. They serve 2 purposes, 1st is the holes where the plug go helps when the block is being cast, they release heat and gases if I remember correctly I'm not 100% sure about this but I do know they aid in the casting process. 2nd if the coolant in the water jacket in your engine ever freezes, the idea is the freeze plugs are meant to pop before it breaks the block, leave a pop can full in the freezer sometime you will see what I mean You will need to buy new ones, they CANT be reused, I would only buy brass replacements. The best way I have found for removing these is taking a screw driver on the edge of the plug and hitting it with a hammer, which will make it turn, then pull it free with pilars. To install the new ones, clean the mating surface well, then I put Form-A-Gasket the type the hardens, then get a large socket, the biggest you can find that fits in the freeze plugs so it spreads the weight out good. Then just hammer it into place. |
