It is currently Sun Jun 14, 2026 7:41 am
Post new topic  Reply to topic  [ 48 posts ]  Go to page Previous 1 2 3 4
PostPosted: Sat Apr 08, 2006 8:40 am
The Dupont oil engineer told me that is the best oil for the money on a new engine or a rebuild after break in.
I believe that Mobile 1 is the original fill in BMW as well as some other high dollar imports. It's what I use in my vehicles.
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Sat Apr 08, 2006 9:03 am
The only reason I asked about Lucas was that I have a couple of vehicles that set for long periods between startups and was thinking about the the dry startup issues,after reading that link I beleive Ill just use quality motor oil and pray for the best.Thanks Dan.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Sat Apr 08, 2006 10:22 am
A thickener like Lucas or STP will make that problem worse because they thicken the oil and slow it circulation.You'd be better off with a thinner oil. You could prime the oil pump with vaseline or light grease then spin it over for a few seconds with the plugs out to pump some oil up into the bearings and camshaft. When I was working on phords we used to pull the distributor and spin the rod with an electric drill until oil was circulating. Can't do that with a slant.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
