It is currently Mon Jun 22, 2026 7:44 pm
PostPosted: Tue Apr 18, 2006 4:37 pm
I have a 1966 Dodge Coronet with a nice red, but cracked steering wheel.
Do any of you experienced restorers have any suggestions on a good way to repair these cracks?
PostPosted: Tue Apr 18, 2006 4:52 pm
That's a lengthy and fiddly process, but it can be done with epoxy putty such as PC7. You have to grind/file the cracks so they're V-shaped and free of loose plastic chunks, clean the parent plastic thoroughly, apply the putty and shape it, sand/fettle it to final shape, then paint the whole wheel.
PC7 can be found at most good hardware or home stores. Eastwood has a Kit and a Book.
PostPosted: Tue Apr 18, 2006 5:25 pm
Contributor
I've used J-B Weld a couple of times and it worked well. After 3 years, it still hasn't cracked or come out.
PostPosted: Tue Apr 18, 2006 6:07 pm
POR-15 makes a steering wheel kit also.
82 D150-225/727
02 Dakota-3.9/5 speed
