It is currently Fri Jun 12, 2026 5:53 am
 Post subject: Need u-joint
PostPosted: Wed Apr 26, 2006 1:00 pm
There's a joint in the lower end of my '65 Valiiant steering column that's shot. It isn't the spider type u-joint, but I don't remember the name for it. It has a crossbar in a rectangular "box."
Is there any way on Earth to find one of these?
PostPosted: Wed Apr 26, 2006 4:55 pm
The name of the part is "steering column coupler." Off the top of my head I don't recall who sells them, but they are out there. I think I remember someone advertising them in mopar action but I could be wrong.
PostPosted: Wed Apr 26, 2006 5:12 pm
There are coupler rebuild kits on Ebay or from any Mopar parts dealer. I just put one in my 1992 Dodge van ($15 from dealer) and it is exactly the same part as in my 60s Darts/Valiant.
PostPosted: Wed Apr 26, 2006 6:26 pm
You talkin' about one of these?
www.borgeson.com
82 D150-225/727
02 Dakota-3.9/5 speed
PostPosted: Wed Apr 26, 2006 7:57 pm
Sounds more like this: http://www.jimsautoparts.com/images/Ste ... oupler.jpg
David Kight
'62 Valiant Signet, White
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Wed Apr 26, 2006 10:46 pm
www.borgeson.com
Nope.
PostPosted: Wed Apr 26, 2006 10:50 pm
Yup. It apparently has rubber inside it, and that rubber got oil or gas on it. Now it had a very rattle-bang racket when there are side thrusts on the wheels, specifically, on my neighbor's concrete drive (spread with a tamper instead of a screed.)
Thanks.
PostPosted: Wed Apr 26, 2006 11:27 pm
I've heard them called "rag" joints.
I believe the entire coupler is availible from the dealer as well as the rebuild kits.
Flaming river has u-joint replacments for these factory joints for both manual, power, and power to manual conversion applications. I used a flaming river shaft/joint kit on my car when going from power to manual.
The u-joints help take the slack out of the system thats inherent to the stock style joints, but downside is they are pricy.
PostPosted: Thu Apr 27, 2006 4:46 am
Thanks.
Well, the picture came from Jim's Auto Parts. The entire assembly is available from them as well as parts to repair. There may be other sources as well. I don't know about the dealer; if it's available as a dealer item it would probably be cheaper. The Paddock has the rubber seal for the top of the can but that's about all.
A "rag joint" is a different animal that performs the same function.
David Kight
'98 Dodge Dakota
'06 Jeep Liberty
PostPosted: Thu Apr 27, 2006 11:57 am
I've seen u-joints with a rag and rubber spider.
Thanks
PostPosted: Thu Apr 27, 2006 12:53 pm
http://www.flamingriver.com/index.cfm/p ... prd214.htm
Copy and pasted: This adapter is ideal for picking up header clearance by eliminating the old rag joint with your stock power box.
Don't look at those prices - summit has them for $40 cheaper.
PostPosted: Fri Apr 28, 2006 8:39 am
http://www.flamingriver.com/index.cfm/page/ptype=product/product_id=214/category_id=-1/home_id=-1/mode=prod/prd214.htm
Holy ____! $169????
But they have several for less than half that.
I wonder if anyone has ever tried a straight coupler with no u-joint on the '65 Valiant. Flame and Summit have them. $30 and $27.
PostPosted: Fri Apr 28, 2006 1:28 pm
$169 is retail, summit price is $129....
What do you mean straight coupler? I thought there had to be some sort of joint there because the box and steering colum are at. Otherwise, why would the factory go through the expense?
Please paste link to these straight couplers.
PostPosted: Fri Apr 28, 2006 6:17 pm
I beleive the OEM coupler is like the slip yoke on a driveshaft, it accounts for shaft length during chassis flex.
I don't see where the aftermarket joints have a provision to adjust for flex. This would put a strain on the steer box gears and/or steer column bearings.
Slant Cecil
PostPosted: Fri Apr 28, 2006 9:35 pm
http://store.summitracing.com/partdetai ... toview=sku
http://www.flamingriver.com/index.cfm/p ... prd208.htm
http://store.summitracing.com/egnsearch ... 4294848488
