It is currently Fri Jan 02, 2026 4:52 am
 Post subject: Header Leak
PostPosted: Wed May 10, 2006 3:28 pm
Just installed my Clifford shorty headers and cannot get #3 cylinder sealed properly. Tried double gasket on this tube but no luck. Any suggestions?
PostPosted: Wed May 10, 2006 6:03 pm
well I just went thru a nightmare (I call it headers from hell) tried just about everything with my clifford headers thin to very thick gasket.....rewelded weld rings ...grinded them flat and still leaking.. I am just drive like this for a while and put the stock exhaust back on to continue on my project....
http://www.cardomain.com/id/lncognito
PostPosted: Wed May 10, 2006 6:46 pm
PostPosted: Wed May 10, 2006 8:00 pm
Errr, Dan, what???
'64 Dart GT convertible, 64 Dart 170 2-door post sedan in faded blue and rust (the Az Dart) & a sixty THREE Dart 170 2-door post sedan in faded blue and rust. (future project)
Early Dart Disorder (EDD) is real, and I've got it!
PostPosted: Wed May 10, 2006 9:50 pm
i have the same problem with mine, except it on cyl. 4. i have the stock intake still and i account the leak to difference in thickness between to two manifolds. mine is still leaking and i plan to fix it when i put the clifford 4-bbl mainfold on.
zedpapa
1970 dodge dart w/225 /6 bored .040" over, holley 390cfm w/vac. sec., compcams 252s, clifford shorty headers w/2.5" exhaust w/flowmaster, f-body 11" front discs, aluminum A-833OD, 8 1/4 w/3.21 SG
soon to have 5 gears!!!
PostPosted: Wed May 10, 2006 10:30 pm
My #1 ... or was it #2 was leaking. I called clifford about it and they advised to cut the flange, between the two tubes. This worked for me - guess the flange was warped a bit.
 Post subject: header leak
PostPosted: Thu May 11, 2006 3:08 am
Thanks guys for your suggestions, will try cutting flange today.
PostPosted: Thu May 11, 2006 7:23 am
Errr, Dan, what???
That was me, not sayin' a word.
PostPosted: Thu May 11, 2006 12:53 pm
Cut flange between cylinders 2 & 3. For now leak seems to be sealed, only time will tell I guess. Thanks again!
