It is currently Fri May 15, 2026 12:12 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 6 posts ]
 Post subject: Question for the Doc.
PostPosted: Tue Sep 04, 2001 9:57 pm
I've read an answer to someone's question you posted. Drilling a larger hole in early lower control arms to accept the later, larger lower balljoints from 73-76 disc brake cars. Were there any complications in doing this? Did this prove to be a reliable modification? As far as the upper arms, did you just swap them for the 73-76 arms or did you have a trick for them as well? Sorry about all the questions but I only ask for what I don't know. Thanks for answers that you may give.
drucker@sbcglobal.net
PostPosted: Tue Sep 04, 2001 11:21 pm
: I've read an answer to someone's question you
: posted. Drilling a larger hole in early
: lower control arms to accept the later,
: larger lower balljoints from 73-76 disc
: brake cars. Were there any complications in
: doing this? Did this prove to be a reliable
: modification? As far as the upper arms, did
: you just swap them for the 73-76 arms or did
: you have a trick for them as well? Sorry
: about all the questions but I only ask for
: what I don't know. Thanks for answers that
: you may give.
My comment was that I have "drilled-out" the lower ball joint mounting holes (9 inch drum brake)in order to bolt them onto the early K-H 4 piston Disc Braake spindles. I have never drill-out the control arms.
If you are swapping to the later single piston Discs, your lower control arms will work, you will need the correct (later) ball joints and upper A-Arms.
PostPosted: Wed Sep 05, 2001 2:17 am
: My comment was that I have
: "drilled-out" the lower ball joint
: mounting holes (9 inch drum brake)in order
: to bolt them onto the early K-H 4 piston
: Disc Braake spindles. I have never drill-out
: the control arms.
: If you are swapping to the later single piston
: Discs, your lower control arms will work,
: you will need the correct (later) ball
: joints and upper A-Arms.
: DD
Sorry for the misunderstanding. So if I'm correctly understanding you now you say that the 9 inch drum lower contrl arms will bolt on to the 73-76 disc brake balljoints and all I will need to do is swap my upper arms with the 73-76 upper control arms to mate them with the 73-76 disc brake spindels? Thank you for bearing with me.
PostPosted: Wed Sep 05, 2001 5:28 am
: that the 9 inch drum lower contrl arms will bolt on to the 73-76 disc brake balljoints and
: all I will need to do is swap my upper arms
: with the 73-76 upper control arms to mate
: them with the 73-76 disc brake spindels?
By Jove, I believe he's got it! Yes,you are now understanding it correctly.....early lower arm, later lower ball joint, later upper and ball joint, disc spindle, rotor, and caliper brkt.
Roger
GTS225@aol.com
PostPosted: Wed Sep 05, 2001 10:19 am
If in doubt and you need some 73-76 part numbers to verify, you can go over to slantsix.com and
look up a long post I submitted that had all the part numbers for the disc brake front ends from the 1976 Parts catalog.... that should clear a lot of things up (or give you some invaluable junkyard reference material).
res0aus2@verizon.net
PostPosted: Fri Sep 07, 2001 11:23 pm
: the control arms.
: DD
yup, I did that too. The other way costs money
richard-c@e-d-a.com
