It is currently Tue Dec 30, 2025 10:12 pm
PostPosted: Sat Jun 10, 2006 2:49 pm
I just threw in a hotter coil and 8mm wires. the plugs, cap and rotor all looked good so I didn't change em. even though I bought em. the plugs looked like they were running slightly lean if anything. should I richen up the mixture a tad now that it's got really hot spark?
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sat Jun 10, 2006 2:59 pm
reading plugs ain't as easy as it was. gas additives and the wide variety of temp ranges makes reading plugs really like playing the blind chicken :lol: if you're sure your spark plugs are the correct temp range for your motor, and you sure your gas ain't contains those additives that turns the plugs almost blueish, you can dial in more fuel.
if your electrodes are anywhere from light brown to tan, or even light beige, just leave it if you ain't getting other symptoms like lean surge or overheating or such
Juan Ignacio Caino
PostPosted: Sat Jun 10, 2006 3:30 pm
There is no reason to richen the mixture.
PostPosted: Sun Jun 11, 2006 8:14 am
The spark is exactly as hot (which has nothing to do with heat, but with maximum secondary voltage) as the cylinder pressure, dwell time and engine speed require it to be. Unless your previous parts weren't working the spark is just as hot as it was before.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 13 guests
