It is currently Wed May 27, 2026 9:56 pm
 Post subject: Nos
PostPosted: Mon Jun 12, 2006 3:05 pm
It sounds like you guys could figure out how to put NOS on anyones SL6. I know it isn't a simple formula for every installation, but are there some basic guidelines for NOS on a SL6?
I would really love to see them in print. It sure gets the juices going. :twisted:
bwhitejr
'72 Duster (Performance 360)
'83 Ramcharger (Performance 318)
'80 TrailDuster (360)
'80 D-150 Truck (See Below)
CompCams 252S, Holley 390cfm, Offy manifold
Ported, Polished and Gasket Matched
P4286813 Springs,0.040 Overbore,
0.090 Shaved Head
 Post subject: Re: Nos
PostPosted: Mon Jun 12, 2006 6:10 pm
bwhitejr
Rule #1) Install a NOS set-up, anything that spays the stuff in. :roll:
#2) Never use NOS jet(s) that are larger then the added fuel jets. :x
#3) Always be sure you have enough fuel pressure. :evil:
#4) Run colder spark plugs and turn back the timing about 2 degrees for every added 50 HP.
#4) Keep the NOS bottle full and warm. :oops: :wink:
It does not take much to make a SL6 rock with just a little shot.
Hay... I even figured-out a way to "fog" a 1bbl SL6 manifold!
PostPosted: Wed Jun 14, 2006 3:52 pm
My 60 foot are 2.10 but I leave the line
at idle and soft to the floor. I spray at 70
foot mark in 2nd gear,and let go the nos
at 1000 foot mark. The car crosses the
finish at 5600 rpm's.
I can't get the weight lower with out
braking the law!! :twisted:
PostPosted: Wed Jun 14, 2006 5:26 pm
Put some 3.91's in it and hit the joos on the line. Spraying downtrack and letting go of the button at the 1000 foot mark are killing your times. :shock:
I've tried spraying mine in 2nd and high only and it really doesn't do much for ET, It will pick up lots of MPH though. :lol:
