It is currently Fri May 15, 2026 12:49 pm
Post new topic  Reply to topic  [ 47 posts ]  Go to page Previous 1 2 3 4 Next
PostPosted: Tue Jun 13, 2006 8:56 am
I'm a bit concerned about your turbo's compressor seal. As a former Conquest owner I know that Mitsubishi put the throttle after the compressor. This means, of course, that the compressor was never under vacuum. Turbo I 2.2s used a thottle upstream of the compressor so those little T3s will take vacuum. I own a vehicle with a 16G on a 2.0 liter engine stock. I can't imagine running a 12G on a 3.7L.
Sharp guy! Lets me know I can learn a lot on this site! Yes the seal is a problem, that turbo just wasn't designed for drawthru. As far as turbo size...you should try it. At 10psi boost it screams! Larger means more LAG.
I like low end power. Its in my truck, not a drag car.
1983 Dodge D150 Turbo Slant 6
Carb. 4spd. 2wd.
 Post subject: Re: pic turbo
PostPosted: Tue Jun 13, 2006 8:58 am
The carb height is not ideal, it hits the hood, time for a scoop! :twisted:
What about side-draft carbs????[/quote]
Hey ya run what ya got! :lol:
Carb. 4spd. 2wd.
 Post subject: Re: turbo
PostPosted: Tue Jun 13, 2006 9:01 am
Nice pics of a home built system. What kind of specs on the motor? I am guessing minimal flow work (head/cam) for that turbo to work.
...and Sam, great description of your turbo driving experiences, makes me want one
For that turbo to work? It "works" great! Trust me its not too small, can't wait to dyno :twisted:
Carb. 4spd. 2wd.
PostPosted: Tue Jun 13, 2006 9:19 am
I'm changing my set-up to a blow thru, maybe with an intercooler. Can the stock Carter BBD 2 barrel handle blowthru? Shuold I box in the whole carb?
Been studying carb/ centrf. supercharger set-ups. Image
Carb. 4spd. 2wd.
PostPosted: Tue Jun 13, 2006 2:26 pm
Since you have a Super Six intake on the truck I'd get an adapter and use a Holley 350 2bbl. I'd also port match and taper the adapter to the manifold. The Holley's are much easier to tune than the BBD mostly due to all the literature and parts that already exist. You'll need a boost referenced fuel pump or an electric pump and boost referenced regulator for blow thorugh as I'm sure you already know. For the carb I would start with stock jets, but open up the power valve channel restriction. I'd also change out the power valve for one that opens a bit later (lower number like a 5.0) to help with fuel economy as it will delay getting into the rich power mixture, but still give adequate fuel under boost.
PostPosted: Tue Jun 13, 2006 2:28 pm
Any idea of the exhaust back pressure? When full boost comes on and at red-line?
 Post subject: turbo
PostPosted: Tue Jun 13, 2006 9:17 pm
Thanks Josh, for the tech support. Sounds like you've done this before.
As far as back pressure goes...seems like I've seen that ques before. I have not put a gauge on it. the turbine housing has got over 500F HOT :twisted:
Will the Holley 350 2bbl use an air horn or a carb box for boost?
Carb. 4spd. 2wd.
PostPosted: Wed Jun 14, 2006 12:16 am
I wish I had done it. I have an interesting mock up picture somewhere of my /6 turbo ideas.
The Holley 350 can use the same carb hat as a Holley 4bbl. I have a Turbonetics hat, but it's just sitting on my normally aspirated 318 van as the throttle linkage for the 4bbl swap was a PITA.
 Post subject: turbo
PostPosted: Wed Jun 14, 2006 9:24 am
so it can use an air hat ? no box...
Carb. 4spd. 2wd.
PostPosted: Wed Jun 14, 2006 10:39 am
yes
PostPosted: Tue Jun 20, 2006 4:56 pm
Back to the topic. :P
Seems Honda is going to finely do a turbo motor. Not that I've been waiting, but I guess they have been ideologically opposed to them in their cars, unless it was a CART car. Probably couldn't compete without one there, though.
The point is, they have an interesting way to reduce lag. Seems they are using a turbo with two scrolls, one small and one large. There is a flapper valve in the manifold, or turbo, that forces all of the exhaust through the small scroll until the turbo spools up, then it opens and let the exhaust flow through the large scroll.
There is a picture of in in the current online magazine Winding Road. Can't seem to get ahold of the picture as it is a .pdf, so I can't post it.
Not sure if it gives you an idea, but thought it might help. Sure seems like you could build a setup using a divided turbine housing, and position a valve between the manifold and turbo to force the exhaust through half the housing until it was making boost. If the housing were sized correctly, maybe it would even double as a boost controller (more area=less pressure=less turbine speed).
Just an idea.
'15 Chrysler 200S V6
'74 Duster 360, factory 4 speed car
 Post subject: Honda
PostPosted: Tue Jun 20, 2006 6:30 pm
Good to hear Honda is headed into turbos, especially something like this. It sounds like it might act like a VATN turbo (variable area turbine nozzle), a good thing for our world.
PostPosted: Tue Jun 20, 2006 9:54 pm
I think Honda is going to use a turbo in their Acura SUV first, then who knows. Not that I keep up with imports. :lol:
Carb. 4spd. 2wd.
PostPosted: Wed Jun 21, 2006 5:26 am
I know that Honda had a little bitty car called the City (presumably it was a riff on the Civic theme) that came with a turbo. Never sold in the United States, but I think it's related to the Fit.
And they also tried to turn the CX500 into a turbocharged sport bike, with mixed results. I'll bet the turbos they put on the CX might be a good choice if you wanted to build a slant with more than two turbos, though. :D
"Mad Scientist" Matt Cramer
'66 Dart - turbocharged 225
 Post subject: honda ,huh?
PostPosted: Wed Jun 21, 2006 6:16 am
so isn't that new honda turbo like two turbos in one?... and would it even fit on a 225?
anything would be great.. want my dart to be a street racer :twisted:
what is the best way to get "turbo air" into the engine? the standard air cleaner assemble obviously woln't do it... i heard turbo city had something, can't rember what.. :D
I like the cars that go VROOOOOM
not the new ones that go wrrrrr -.-;
