It is currently Sat May 09, 2026 5:56 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 2 posts ]
 Post subject: Please, please, please
PostPosted: Fri Oct 12, 2001 7:09 pm
I had an earlier post but unfortunately got no reply. Is there a source for figuring out how my car was originally delivered using the code stamped on the plate in the engine compartment on my '63 Dart? Thanks
mhoffperson@msn.com
PostPosted: Fri Oct 12, 2001 10:01 pm
: I had an earlier post but unfortunately got no
: reply. Is there a source for figuring out
: how my car was originally delivered using
: the code stamped on the plate in the engine
: compartment on my '63 Dart? Thanks
The "fender tag" does not really give much info. See if you can find a "brodcast sheet" which will give much more detailed information.
I do not have the correct year collision manual or the Dealer Option code sheets needed to decode a 63 Dart.
What info. are you after? Body Style, Trim Code, Piant Color?
