It is currently Sat Oct 10, 2026 6:44 pm
Forum locked  This topic is locked, you cannot edit posts or make further replies.  [ 9 posts ]
 Post subject: O-rings
PostPosted: Mon Oct 22, 2001 10:15 am
I need to replace the o-rings on my sparkplug tubes,where can I get them?
thanks
rj@flyingcamel.net
 Post subject: Re: O-rings
PostPosted: Mon Oct 22, 2001 2:58 pm
: I need to replace the o-rings on my sparkplug
: tubes,where can I get them?
: thanks
Try the local hardware store. They should have a large assortment of o-rings in the plumbing department.
latvalam@msoe.edu
PostPosted: Mon Oct 22, 2001 3:38 pm
I wasn't sure if they would take the heat.
rj@flyingcamel.net
PostPosted: Mon Oct 22, 2001 4:48 pm
: I wasn't sure if they would take the heat.
I'm not sure what is different between various o-rings, but I have been using the o-rings from the hardware store on the exhaust pipe of my dirtbike, with good results. I think it's worth trying; the o-rings are pretty cheap (less than a buck a piece), so even if they don't hold up right, you won't be out much more than the time it takes to change them. Good luck!
latvalam@msoe.edu
PostPosted: Mon Oct 22, 2001 9:06 pm
I have a few sets left over from engine overhaul gasket sets. I only have the newer heads that do not need them. If I can find them I can mail you a set for cheap. They have a square cross section, not round like you get at the hardware store.
cfield@ll.net
PostPosted: Mon Oct 22, 2001 10:38 pm
: thanks
Hi,
You can get the o rings which are the same as the ones used on Hemi rocker covers from buymopar.com look in restoration parts link. I think they are a standard mopar part number P1947708.
Regards
Richard
richard.e.moore@paradise.net.nz
PostPosted: Tue Oct 23, 2001 7:38 pm
Hey RJ,
I got mine through NAPA - they had them in back on the shelf even! As was posted before, they have a square cross section and worked perfectly for me. Also, they were only a couple of bucks.
Good luck,
Dan
gramma@dm-tech.net
PostPosted: Fri Oct 26, 2001 10:21 am
Thanks to everyone for their help,found them at NAPA AUTO PARTS,part#B45384 cost $6bucks.
RJ
rj@flyingcamel.net
PostPosted: Fri Oct 26, 2001 2:50 pm
: thanks
FYI: When I had my shop years ago, we gave up on the stock o-rings because they harden so quickly. We found an o-ring from Motion Industries (#2-218) that is good to 257º. I never had any wear out. You can usually get o-rings from a bearing supply store.
Chuck
webmaster@omnipages.com
