It is currently Mon Apr 27, 2026 2:06 am
PostPosted: Tue Aug 15, 2006 9:14 pm
I got my engine stock with a Holley 1920 carb, but I want to install a vacuum gauge to see if everything is ok in my engine, but the question is, Where I should plug the vacuum gauge? and wich are the normal vacuum readings?
Mopar Muscle is well defend by Slant Six!
Valiant Duster 1971
PostPosted: Wed Aug 16, 2006 12:22 am
When I adjust and tune my carb, I use the vacuum port for the air cleaner door. If you don't have the stock air cleaner, use the port for the vacuum choke pull off....just make sure your engine is fully warmed up. Both of these ports are on the driver side. I believe any reading between 16-20" is a good reading at idle. Make sure the needle is steady....fluctuating could mean a number of different problems. For reference, my stock engine reads 18" at idle. Never drove with a vacuum guage in the car, so can't help you there. If you do, put a "T" fitting in the choke pull off hose and route the hose into the passenger compartment.
PostPosted: Wed Aug 16, 2006 9:57 am
Many AC cars have a small vacuum tap right near the power brake vacuum line that is a good place to T- off a vacuum signal.
PostPosted: Wed Aug 16, 2006 8:19 pm
So I can use the port for the air cleaner door (left side of choke pull of) right?
Valiant Duster 1971
PostPosted: Thu Aug 17, 2006 12:46 am
Sure. In cold or cooler weather, I use the vacuum choke pull off though. The door on the air cleaner regulates how much heat the engine gets, and (I feel) helps adjust the carb more accuratly.
PostPosted: Thu Aug 17, 2006 7:31 am
Thanks Eric.
Valiant Duster 1971
PostPosted: Thu Aug 17, 2006 11:14 am
