It is currently Thu Jan 01, 2026 2:30 am
PostPosted: Wed Nov 01, 2006 5:35 pm
This is the carb My question is what do I need to hook up on a 73 slant the carb is a 75 also how does the kick down linkage connect
1956 Dodge D100 Pick up
power plant 225 slant six
PostPosted: Wed Nov 01, 2006 5:37 pm
PostPosted: Wed Nov 01, 2006 5:40 pm
Here is the linkage that I got form a Volare at the junk yard will this work with this carb? I still think I need more linkage to connect to the kick down rod from the tranny.
 Post subject: Yipes!
PostPosted: Wed Nov 01, 2006 6:05 pm
Somebody correct me, but the Volare gave you a kickdown throttle link and throttle spring retainer for a 2 barrel super six setup....
The 1975 setup doesn't require a throttle return spring as the Holley 1945 already has one integral to the carb (and the 1973 Holley 1920 also).
The kickdown link basically is an adjustable rod that connects on the lowest hole on the throttle lever, the cable hooks to a hole higher on the lever (using a 'peg' with a cotter pin/'hairpin').
Wish I had a pic for you, but I'm in the middle of swapping heads and a more leak free intake on my Beater Valiant...
 Post subject: Re: Yipes!
PostPosted: Wed Nov 01, 2006 10:19 pm
Technically no, it doesn't require one to operate, but for safety reasons, it's /highly/ recommended.
Used to own:
'82 Dodge D150
Erson 270 Cam, O/S valves, mild port work, ~9.5:1 compression
Currently fighting with an '85 VW Cabriolet
My other passion
PostPosted: Thu Nov 02, 2006 6:24 pm
Any suggestions as to what ports/ hoses should be hooked up on this carb I am running a Ford carb now so I can not just plug in the hoses also any suggestions on where I can locate the kick down rod. i posted in the parts wanted forum. Jim
PostPosted: Fri Nov 03, 2006 8:16 pm
See if this helps.
82 D150 Slant6 Shorty
http://www.cardomain.com/ride/658846
PostPosted: Sat Nov 04, 2006 4:13 am
See if this helps.
Thanks that is exactly what I was looking for !!
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 1 guest
