It is currently Wed Dec 31, 2025 5:09 pm
PostPosted: Sat Nov 04, 2006 6:02 pm
The 1963 a body needs a new engine, and I have a 1974 gold duster for parts. Will a later slant 6 bolt up to a push button trans? What would I have to change to make it work?
PostPosted: Sat Nov 04, 2006 7:50 pm
You'll need to use the 1963 oil pan and oil pickup tube. You'll also need the ¼" adaptor ring for the later engine to work with the early torque converter -- you can get the ring from tflitepatty@verizon.net .
