It is currently Wed Jun 03, 2026 9:09 pm
PostPosted: Sun Nov 12, 2006 3:32 pm
I have a 64 valiant 4 speed thats in the exhaust shop right now. I just got a preview of the exhaust routing my muffler guy came up with and I'm a little perplexed. He's running the front pipe under the lower control arm. He doesn't believe I'll have clearance problems, and if I do he will surely hear about it and fix it. any one else run pipes this way? more to come when he's finished. probably thursday or friday
64' Valiant Signet 5.9, 64' Dart 170 moredoor 3.7, 67' A100 3.7, 00' Dakota SLT 4.7
PostPosted: Sun Nov 12, 2006 5:24 pm
Under the control arm...?! Are ya sure? That's way out of the way, kind of like going from Los Angeles to San Francisco by way of Topeka. Are you sure he didn't mean he wants to route the pipe under the steering arm?
PostPosted: Sun Nov 12, 2006 5:39 pm
no, I just saw it. He put the pipe straight down from the front manifold and under the control arm. the car is at ride height on his lift and there is clearance. It runs just inside the torsion bar adjuster. and then over the steering. It's actually not the lowest point under the car. the tie rods and pitman arm are still lower. I'll let ya know when it's finished
PostPosted: Sun Nov 12, 2006 6:38 pm
Car Model: 62 Lancer GT
I'm very interested in how this comes out. I'm getting ready to do this on my 66 dart with 4 spd. and it does look tight for 2 pipes. Does anyone have pics of a working setup?
1966 Dart GT
4 spd. OD conversion
8 3/4 - 3.55 SG (Sold)
62 Lancer GT
B Body 8 3/4
PostPosted: Mon Nov 13, 2006 2:51 am
Back in '85 I put a set of Clifford headers on my 65 Dart GT convert w/PS and IIRC the front 3 went down thru the K Frame and then back. Don't think any part of the exhaust was routed under the lower control arm. Maybe beside it - but that was 21 years ago and the memory is a little hazy on that.
PostPosted: Mon Nov 13, 2006 6:05 am
I know clearance is tight on the early a-bodies, but after my eperience with headers on my Swinger back in High School (a 318, admittedly), I'd never wat to go back to any exhaust that goes under the suspension. I literally bottomed-out my brand new Hedmans a few blocks away from the muffler shop that installed them. And that was at stock ride height. If it were me, I'd find another way.
vm
PostPosted: Mon Nov 13, 2006 5:08 pm
Exhaust is done and it sounds awesome. nice deep throaty acceleration with that six cylinder wrap. great idle sound. I think it sounds better then my neighbors 5.0 mulestain with flowmasters. however he hadn't fully checked clearances yet and the pipe that goes to the stock manifold hits the center link so he's gotta fix that and I'll probably get it tommorow. as for the funky front pipe routing, if it becomes a problem I will let ya know.
PostPosted: Tue Nov 14, 2006 7:29 pm
I am running Dutra Duals on a 170 in a 60 Valiant and was able to run two 2 inch pipes down through the stock location even with a 4spd bellcrank and even though its tight it clears without hitting anything.I used 2inch mandrel bent u-sections from Summit and welded the whole system myself after the local exaust shop looked at it and quoted me a price of $400.
HyperValiant
1960 Hyper-Pac Valiant(rolling test-bed)
1963 Valiant V2OO(Son's summer project,- he just turned 15 :-) )
1972 Valiant 4dr(Daughter Kelly's repair in progress)
1974 Valiant (v8) daughter Kelly's work in progress
PostPosted: Wed Nov 15, 2006 5:59 am
Pics? Please? I'd like to see photos of this - and other - headpipe routings for the Dutra duals, especially on narrow-body A's.
PostPosted: Wed Nov 15, 2006 10:30 am
How about the Dutra Duals set-up on my 1965 Barracuda?
PostPosted: Wed Nov 15, 2006 6:41 pm
Is the front tube dented to clear the steering?
1966 Dart GT
62 Lancer GT
B Body 8 3/4
PostPosted: Wed Nov 15, 2006 9:42 pm
Yes. I believe the pipes are 1.5" (to match the manifold outlets) and the dent was required for clearance.
PostPosted: Thu Nov 16, 2006 8:38 am
Those don't look like 1½" pipes to me, more like 2" (which would match the manifold outlets).
PostPosted: Thu Nov 16, 2006 9:23 am
You're right, I goofed! I just checked the OD of the pipes and it's ~2¼" from the manifolds to the tailpipe.
PostPosted: Thu Nov 16, 2006 4:09 pm
Car Model: 1964 Dart GT
[quote="64'4$peed"] I think it sounds better then my neighbors 5.0 mulestain with flowmasters. quote]
Haha... Mulestain...
I have a 64 Dart 4 speed with Clifford shorty headers, 2.5" pipe and we got the pipes between the powersteering box and the clutch linkage, no problems.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 8 guests
