It is currently Mon Dec 29, 2025 8:44 pm
 Post subject: starting problem
PostPosted: Sun Nov 19, 2006 2:26 pm
i have a fresh rebuilt 225 1bbl
new battery(good alternator)
NOS holley carb
new therm. choke.
it sometimes starts, and at other times doesn't. It wants to heel over but can't.
it'll start more than the times that it wont, but i cant keep guess and checking.
help
________
HERBAL STORE
Last edited by 15Standtriumphant on Thu Feb 10, 2011 6:21 pm, edited 1 time in total.
PostPosted: Sun Nov 19, 2006 2:49 pm
Need more detail—a lot more. What do you mean by "heel over"? You mean sometimes it won't crank? Sometimes it'll crank but not start? If the latter, do you get any sputtering or other indication that it might be close to starting, or is it just endless dry cranking? Does this happen when the engine's hot? Cold? Both/either?
PostPosted: Mon Nov 20, 2006 5:58 am
It also might help to know what year model and vehicle this engine is in (I'm guessing a '73 Swinger). Is it is manual or automatic transmission?
Jerry
PostPosted: Mon Nov 20, 2006 7:54 pm
it is a 1973 dart swinger.
automatic tranny
i get the sputtering, or sound every other carburated engine gets right before starting, but it wont start.
the starting isnt affected by the weather, it had started in both dry hot, and wet cold. however, it does start right away after usage when the engine's warm.
few other things that have happened is that it takes really long to warm up. if i start it, and put it in D a few seconds later, the engine will sometimes die out. If it doesnt die, it'll take a real long time and a heavy foot to get that first roll.
ive noticed that i have a slight tranny slip on my second speed, and when i put it in drive on a flat surace the car will not roll forward by itself.
-thaks for the replie. i know i was all over the place on my info, but i hope it's sufficient.
-Saul
________
TRICHOMES
________
Synthetic Weed
Last edited by 15Standtriumphant on Thu Feb 17, 2011 6:47 am, edited 2 times in total.
PostPosted: Mon Nov 20, 2006 8:05 pm
Sounds to me as if the idle speed is adjusted too low, the choke is maladjusted and/or faulty, probably the idle mixture isn't set correctly, and there may be a problem with the trans kickdown linkage. Can you tell us in specific detail what work you've done so far?
PostPosted: Mon Nov 20, 2006 8:18 pm
the only true "detailed" work I 've done is replace the old choke with a new one. :oops:
would it help if i took pictures and posted them to show my possible maladjusted choke, or could somebody tell me how to adjust it?
ps. thanks slantsixdan
________
Gs850
________
Iolite Vaporizer Review
Users browsing this forum: Majestic-12 [Bot] and 2 guests
