It is currently Fri Jun 19, 2026 12:12 pm
 Post subject: slantsix in the cold
PostPosted: Sun Nov 26, 2006 6:50 am
a friend of mine just drove home a 82 1/2 ton pickup from mainland canada, he had someone else replace the aluminum manifold which was leaking with a cast iron.the problem is cold weather driving, he said there was some kind of heat sheild under the carb,i never heard of be for, so i made a stove pipe connection to the breather and adjusted the choke, she starts fine, warms up, comes of the choke fine but the drivablity untill the engine totally warms up is bad, very flat and boggy no pulling power in 3rd, 4th is usless,i have driven auto slantsixs in these condition and never had this trouble with no heat riser or stove pipe, although on this truck the stove pipe seems to have helped a bit, any taughts or experences with this would be apprecated.
PostPosted: Sun Nov 26, 2006 7:45 am
The heat shield was a big plate of aluminum or pressed asbestos :shock: sandwiched between carburetor and intake manifold, used on some late '70s to '80s applications to try to control hot start/hot idle problems. The fuel line mod works better than the heat shield did.
Cold driveability: Choke, exhaust manifold, heat riser valve, thermostatic air cleaner, and coolant-controlled EGR system are your prime suspects.
The choke thermostat, choke thermostat heater, choke modulator, choke pushrod and choke pull-off all have to be in good working condition, hooked up correctly and adjusted properly. The factory choke thermostat cannot be adjusted; the electric choke kits replace the original thermostat, modulator and rod with new fully-adjustable ones. Choke pull-off is adjustable and replaceable.
Not sure what you mean by making "a stove pipe connection to the breather". The breather is the can-looking device at the top rear of the valve cover, with a 5/8" hose conecting it to the air cleaner. The stovepipe runs from the sheetmetal stove surrounding the centre collector area of the exhaust pipe to the connection on the underside of the air cleaner's snorkel snout (maybe you were calling the air cleaner the "breather"?). Check that the air cleaner control hoses are routed correctly according to the factory service manual diagrams. Check that the hot/cold air damper door is in "hot air" position until the engine is well and truly hot, and that it's in "cold air" position after that. Check that the damper door actuator (round device atop the air cleaner snorkel snout) is in good condition and doesn't have a leaky vacuum diaphragm. Replacement air cleaner temperature sensors are available.
If the exhaust manifold is cracked or the intake-to-exhaust manifold gasket junction leaks, exhaust will be sucked into the intake tract when the air cleaner is in "hot air" mode. This will really do a job on driveability, so check carefully for cracks and blowing leaks.
The exhaust manifold heat control valve needs to operate correctly. Get a can of 4318039AB solvent from your nearest Mopar dealer and apply it to the valve. Liquid Wrench, etc. aren't substitutes!
The EGR system on this truck, if it is (still) so equipped, is a coolant-controlled system. There are temperature-sensitive control valves that prevent vacuum reaching the EGR valve until the engine coolant has warmed up. If one or more of these valves are defective, the EGR system will be operative with a cold engine, which will have the same deleterious effect on driveability as cracks or blowing leaks described above.
What is the condition of the carburetor on this truck?
PostPosted: Sun Nov 26, 2006 12:32 pm
thanks for the impute, i ran the egr line to one of the port vacum tube on the carb never thaught of hooking it up to a temp control vac fitting,i will try that ,as for stove pipe route i should have said air cleaner ,everything else checks out except for the spring on heat riser counter weight :D
PostPosted: Sun Nov 26, 2006 12:40 pm
how is the carb, it seems it good condition, idles will but i cant adjust air screw ,need square head screwdriver,small pop in exhaust at idle but other than the warmup problem everything seem fine. :D
 Post subject: Re: slantsix in the cold
PostPosted: Sun Nov 26, 2006 1:09 pm
The EGR hoses all have to be routed correctly. Don't just guess and place 'em randomly. Direct from carburetor to EGR valve isn't correct, and neither is from carburetor through temperature-controlled vacuum solenoid to EGR valve. The EGR vacuum amplifier (looks like a hockey puck, bolted to the top of the head needs to be plumbed in correctly. Get the factory manual and put it all together like the book says, or delete the EGR altogether.
That's an important part, needs fixing.
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 3 guests
