It is currently Tue Jun 16, 2026 6:36 am
 Post subject: Whew!
PostPosted: Sun Nov 26, 2006 6:18 pm
Me and a couple of buddies dropped the rebuilt slant in over the holiday weekend. Still got lots to do before fire-up, but I have a couple of questions...
In both the engine gasket set and with the new Melling oil pump, there was a 1" long plastic tube, but no instructions on what its for. I notice it could fit perfectly in the oil filter standpipe — is that where it goes, and what function does it serve? I pulled the standpipe from the old pump, but didn't find anything...
Second question: In getting the engine back to top dead center to drop the distributor, it needs to be on the compression stroke, right? How do I determine that?
Thanks in advance! Pictures soon. (I chose a different color scheme... always the artist!) Almost there...
vm
PostPosted: Sun Nov 26, 2006 6:34 pm
Can't imagine what that plastic tube might be.
Compression stroke: Yes. Determine it by looking at the rocker arms on the frontmost cylinder. When they're both relaxed (valves closed) you're at the correct TDC.
PostPosted: Mon Nov 27, 2006 5:35 am
Thanks as always, Dan!
vm
PostPosted: Mon Nov 27, 2006 6:03 am
Or...
A fingertip sealing off the spark plug hole will feel the compression trying to push it away. :wink:
Jerry
PostPosted: Mon Nov 27, 2006 8:48 am
also, when #1 is at true TDC you should be able to rotate them pushrods with your fingertips. If you're using a near stock cam, when #1 is at TDC #6 intake sould be depressed.
Juan Ignacio Caino
