It is currently Tue Jun 23, 2026 2:45 am
PostPosted: Fri Mar 16, 2007 12:00 am
65 valiant is a 100 model, so it didnt come with the backup light bulbs/wiring...yet I see the wiring there ready to go..near the stop light wiring
anyone know what is needed to make both backup lights work?
Is it as simple as hooking up a bulb/housing inside the backup light and connecting to the little connectors?
thanks!
PostPosted: Fri Mar 16, 2007 12:08 am
My 64 V100 has backup lights...........
connect a light bulb up and see what happens.
PostPosted: Fri Mar 16, 2007 11:38 am
NOS backup light kits turns up on Ebay once and a while. So far I've seen only one Valiant that didn't already have it.
Never seen a Valiant I didn't like!
PostPosted: Fri Mar 16, 2007 4:11 pm
Any way you could post a pic of urs?...thanks!
Im confused why the driver side unit has 2 wires going to 1 connector and the passener side has 1 wire going to 1 connector for the backup lights?
PostPosted: Mon Mar 19, 2007 2:25 pm
If both wires go to the same point in the one connector, they just made the connection there rather than a splice in the harness.
I seem to remember that the backup light switch moved from the shifter to the trans in '68, but I may be wrong. Anyway, while the later 3 pin switch will screw into the early trans in place of the 1 pin switch, it won't work right unless you change the arm inside the trans (the reverse lights will be on in R &D,2,1). I swapped a later arm in to make it work, but it was somewhat difficult. It would be easy if you already had the trans out for rebuilding.
I would recommend putting a good quality microswitch on the shifter to run the backup light. One of the 6? pins on the body harness connector is probably already connected to the sockets.
PostPosted: Mon Mar 19, 2007 4:48 pm
thanks for the info!
My floor shift B&m has a micro shifter on it for the reverse already...ill hook up a bulb in the rear and see what it does in reverse
