It is currently Tue Oct 13, 2026 12:24 pm
 Post subject: Build Up
PostPosted: Mon Mar 19, 2007 7:07 pm
My dad just bought me a 65 Valiant with a 170 slant six. I wanna know what i can do to make it a little hotrod and maybe turn 13's at the track.
PostPosted: Mon Mar 19, 2007 7:31 pm
Time to ask Dad for a Pro Fogger setup......
PostPosted: Tue Mar 20, 2007 5:16 pm
Yeah I was thinking a turbo and some other things.
PostPosted: Tue Mar 20, 2007 5:17 pm
I'm having trouble finding a cam for it. Any ideas?
PostPosted: Tue Mar 20, 2007 5:30 pm
In general, a 170 can't take as much lift increase with-out notching the piston tops.
The shorter stroke can rev to 7500 RPM without much problem, if you can get it to flow some air at that RPM.
PostPosted: Tue Mar 20, 2007 6:10 pm
SSRN National Champion
Id say about 7000 dollars. Thanks Ron Parker :D
Bagels Juiced Im Bamboozled
PostPosted: Tue Mar 20, 2007 6:53 pm
So I'm guessing I shouldn't cam it?
PostPosted: Tue Mar 20, 2007 6:54 pm
A lot less then that in my 170, and in a heavier car
PostPosted: Tue Mar 20, 2007 7:23 pm
Is It a Daily driver a shoot on the scoot. Drag Car 13 seconds on a street 170 easy. Thanks Ron Parker :D
PostPosted: Wed Mar 21, 2007 5:32 am
Do you mean me?
Mine is not a daily driver, do to an 8 inch converter and 4.56 gears, but it is street legal. I do drive it locally. The engine is a "daily driver" build, but with a fogger system.
PostPosted: Wed Mar 21, 2007 8:12 am
If it is a street car, a mild cam will help it, but then you will also need more carb. (Super Six)
Put a 225 into the car, that would give it a lot more "seat of the pants" power.
PostPosted: Wed Mar 21, 2007 5:37 pm
Ahh I don't really have the money for a 225 haha. Dads buying the car but I have to pay for all the performance mods I want to do to it.
PostPosted: Wed Mar 21, 2007 5:41 pm
Plus I like the idea of the 170 reving higher.
PostPosted: Wed Mar 21, 2007 6:22 pm
The only thing I was meaning to do you want it to go 13.00 or 13.99 that would make a big difference. No I was not talking about you Charlie You make 170 Slants do stuff they should not be able to do. Yes you can do this for a lot less but it is tuff to get a street driver vs a street legal car to go that fast. Juice would do it but you need a good engine build and have the knowledge like Charlie to do this. But to go that fast you are looking at transmission stronger rear end and ect. Thanks Ron Parker
PostPosted: Wed Mar 21, 2007 6:24 pm
If you're really on a budget, then start with a "Super Six" 2 barrel carb and intake, available in many junkyards and often seen on eBay.
You could also remove the head and mill it down for increased compression, not very expensive at all.
Changing to a higher numerical ratio rear end will give you a "seat of the pants" feel.
Nitrous will shave off some 1/4 time.
As with any car, make sure your braking system and suspension (inc. ball joints, tie-rod ends, bushings, etc) are in good shape BEFORE you spend money on making it go faster.
-Mac
